Need 3Bar Offset Values
Old Jul 6, 2010 | 08:14 PM
Slow Z06's Avatar
Slow Z06
Default Need 3Bar Offset Values
I need the Linear and Offset values for a GM 3Bar sensor. Part number 12223861
Tried searching but came up empty. Thanks
Here is a link to the Delphi sheet but I honestly dont know how to read this.
http://not2fast.com/electronics/comp...P_12223861.pdf
I found this chartfrom here:
http://www.robietherobot.com/storm/mapsensor.htm
So would that mean my offset is 3.6?
Old Jul 6, 2010 | 09:11 PM
Mike04's Avatar
Mike04
What tuning software are you running, most have a 3 bar OS upgrade that is plug and play for the 3 bar.
Old Jul 6, 2010 | 10:04 PM
Slow Z06's Avatar
Slow Z06
hptuners however it did not add in the offset values. I think I got it now 305 kpa/4 offset that gets me 98 kpa at startup. Ill move up to a 6 ffset and that should get me a 100 kpa
Old Jul 6, 2010 | 10:54 PM
Mike04's Avatar
Mike04
Not sure if this helps,
My 30 psi auto meter gauge setting to log only boost
The default 3 bar PID in the scanner
Old Jul 6, 2010 | 11:04 PM
Slow Z06's Avatar
Slow Z06
These are the tables I need settigs for.
Old Jul 7, 2010 | 07:00 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
We talked on the phone on how to get the offset nailed down. Did you try it? If it's not working, send me a startup log.
Old Jul 7, 2010 | 10:46 AM
Slow Z06's Avatar
Slow Z06
Got the offset nailed in. Thanks Brett. How about that 106 table above? Do I need to change the values for it now that I went up to a 3bar?
Old Jul 7, 2010 | 11:13 AM
BLOWNBLUEZ06
Text coming your way.
Old Jul 7, 2010 | 11:25 AM
Slow Z06's Avatar
Slow Z06
Thanks B-man
Old Jul 7, 2010 | 04:06 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I am following this thread since I have the tuning school package and I can drink all and any info needed to deepen my knowledge for tuning!
At least I know what I am lookng at now
Thanks,matt
Old Jul 7, 2010 | 04:08 PM
madmatt9471
Hey Mike,
Do you have your PID by chance for the Autometer Fuel Pressure set-up - I was thinking of logging fuel pressure too. I too have the Autometer gauge set-up.
Any and all info on how you set it up would be cool, ONLY when you get a chance.
Thanks,Matt
Old Jul 7, 2010 | 04:49 PM
BLOWNBLUEZ06
Originally Posted by madmatt9471
Hey Mike,
Thanks,Matt
Until he answers, ([PID.2811]/.04)-12.5 is what I used for the EGR and I had to put EGR position voltage in your table to be able to log it. It works great!
Old Jul 7, 2010 | 06:48 PM
Mike04's Avatar
Mike04
Hey Mike,
Thanks,Matt
Autometer fuel pressure gauge is a pre-loaded PID
Old Jul 8, 2010 | 08:57 AM
madmatt9471
Okay cool I found that. Now,
(1) Which wires did you use for the signal coming off the sender or gauge?
(2) Where on the HP Tuner Interface did you install the wires?
On my Wideband I am already using #1 and #5 for the signal.
Let me know once you get a break
Thanks,Matt 661-406-7516
Old Jul 8, 2010 | 12:40 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
The purple wire in the harness is the signal wire.
As for where to install them, you only have one wire and you can put it in any of the 3 additional ports in the harness.
It is pretty straight forward.
I usually log WB, FP, Alky Pressure or Nitrous Bottle Pressure, depending on the car we are running the setup on. The information that can be gathered is awesome.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Jul 8, 2010 | 06:29 PM
Mike04's Avatar
Mike04
Sounds like you are taken care of. If you need any thing let me know.
Mike
Old Jul 8, 2010 | 09:11 PM
madmatt9471
Mike
Perfect, thanks fella's
Thanks,Matt
To Need 3Bar Offset Values
