AlkyController/ Methanol Question
Old Aug 29, 2010 | 01:06 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default AlkyController/ Methanol Question
How often do you rebuild or replace your pump?
Old Aug 29, 2010 | 01:33 PM
Slow Z06's Avatar
Slow Z06
I bought my kit used and the pump lasted 6 months, I replaced with a new pump over a year ago, no issues
Old Aug 29, 2010 | 03:03 PM
396375's Avatar
396375
St. Jude Donor '08-'09
As a preventive maintenance every 2-3 seasons of racing the pump should be changed as a proactive measure. Just like you should on fuel pumps, differencial fluid, brake fluid, etc. If you store the car for winter, drain the system and flush it out with tap water. If stored in below freezing, add some meth to the water so it doesnt freeze. Doing this will extend the life of the pump. Its not about mileage its about time in contact with methanol. Like putting your finger in acid. Methanol over time will go through the pumps head. They are rebuildable as long as water has not gotten into the motor.
Old Aug 29, 2010 | 03:39 PM
Mike04's Avatar
Mike04
Every 2 years is a good measure especially if your tune depends on it. Mine last 4 years without issue before I replaced it. I wouldn't recommend going that long though, what was I thinking.....
Old Aug 29, 2010 | 04:18 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I've had my meth system for two year and every spring I have to replace my pump. Seems water gets in the motor from the top causing corrosion. The last one that I bought from Julio has a rubber glove sort of over the top that comes 3/4 down. We'll see if I have to replace it next spring.
Old Aug 30, 2010 | 05:21 PM
Slow Z06's Avatar
Slow Z06
Call Julio and see what he recommends.
Old Aug 30, 2010 | 08:39 PM
Julio's Avatar
Julio
To AlkyController/ Methanol Question
