Lunati / JE & Ross pistons .... anyone?
Cruise-In II Veteran
Cruise-In III Veteran
Anyone convert over to a more robust forged piston in their NOS or FI setup ? If so - what spec and brand did you use , for the stock 346 block ? ...
Re: Lunati / JE & Ross pistons .... anyone? (jbsblownc5)
Both are good. JE is often considered the best.
I hear Ross has been pretty good the past 2 years, but prior to that some people had some issues.
Re: Lunati / JE & Ross pistons .... anyone? (BLISS)
Rob :confused:
Re: Lunati / JE & Ross pistons .... anyone? (mackeyred96)
Yep ... John, this Z may get forged pistons :) (soon, I hope)
Rob,
You can't go wrong with the JE's, or even their SRP line which are just as strong. From what I understand, they aren't finished as nice, like that matters, right. You can save about $100 on a set by going with JE's SRP line.
BTW, what plans do you have? Let me guess...uummm... a BIG shot of gas?? :smash: :)
Mike
Mike
Received 5,217 Likes
Have used Ross successfully, but find Arias lighter and have run them to nearly 1000 hp with 38# of boost (twin-turbo) at B'ville and set records. :yesnod: All the best.
