Injector/fuel pump recommendations
Old Sep 20, 2010 | 10:44 PM
b16gsr's Avatar
b16gsr
Default Injector/fuel pump recommendations
I am working on a boosted project over the winter for my 99 Corvette. Car has 45k miles on it and is in perfect running condition.
Here is the plan so far:
Cerra Front mount Single turbo kit with a 62-1 and required accessories
Comp 918s and retainers
02+ Z06 cam
LS6 intake
LS2 HD timing chain
LS7 clutch
My intentions are low boost 6 to 8 lbs, shooting for 450whp maybe a little more. I just want reliable fun horsepower, not going to go crazy or anything.
I am going to run E85, and wanted to know what injectors and fuel pump to run.
Any suggestions?
Old Sep 20, 2010 | 11:13 PM
dsmlights's Avatar
dsmlights
02+ Z06 cam
LS6 intake
LS2 HD timing chain
LS7 clutch
Any suggestions?
6-8 psi will get u close to 550 or so, i am making 493 on 8psi on e85 maxing out 60 lbs injectors and lpe fuel pmp with the rewire. Get the dual intank setup or go with the AA fuel system. as for injectors got with some 80s at least .
Old Sep 20, 2010 | 11:16 PM
b16gsr's Avatar
b16gsr
okay maybe i will only run 4 to 6 psi. i want SAFE horsepower. i do not want to take worry about blowing it up, just want fun and safe.
i was told 80's but thought they may be too big.
To Injector/fuel pump recommendations
