using a resistor to pull timing?
Old Oct 12, 2010 | 06:00 PM
bentley14's Avatar
bentley14
Default using a resistor to pull timing?
has anybody here used a resistor to pull timing if so what size resistor and details please!!
Old Oct 12, 2010 | 06:37 PM
Z06supercharged's Avatar
Z06supercharged
Why mess with a resistor when you can do anything withtiming within the tune settings? There are more ways and tables to pull timing than you could imagine.
Old Oct 12, 2010 | 06:47 PM
SargeZ06's Avatar
SargeZ06
I do it. I use a 220ohm resistor and set my IAT Spark Base table to -9 degrees for 167 and above. Works like a champ.
Old Oct 12, 2010 | 11:57 PM
396375's Avatar
396375
St. Jude Donor '08-'09
http://www.casperselectronics.com/st...roducts_id=701
Old Oct 13, 2010 | 04:18 AM
SBCGENII's Avatar
SBCGENII
What he said, . I wouldn't do it on a FI car where i would want to log accurate data to base a tune off of.
solution= hp tuner, ls1 edit, tunercat, efi live.
Old Oct 13, 2010 | 04:26 AM
SBCGENII's Avatar
SBCGENII
That thing is pretty cool you might get away with one tune for race and pump gas with that. If you have a boost controller maybe even add a couple pounds of boost if your switch from the ethanol/gas to a straight high octane fuel.
To using a resistor to pull timing?
