Fuel system help?
Old Oct 15, 2010 | 04:09 PM
PhilsZ51's Avatar
PhilsZ51
Default Fuel system help?
I am looking at a fuel system from a member on another forum, and he said that it will support 800 wheel. It's aeromotive fuel rails and FPR, all upgraded lines and
fittings and it comes with a racetronix upgrade and a Walbro GSL395 PN# VPN-GSL395. He said that he ran this pump at 18.5 volts and made 900 wheel in his turbo setup.
Seems like a real nice guy, just wanted to make sure this pump is capable of that because another buddy said that pump can't even support half of that.
Old Oct 16, 2010 | 10:20 AM
396375's Avatar
396375
St. Jude Donor '08-'09
Even if the pump did support that kinda power, 18.5 volts is .At a sensible voltage it's only good for 300 HP on a FI application.I'd pass on that deal unless the rest of the parts are a good deal without the pump.
Old Oct 16, 2010 | 10:35 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
There must be some mistake with this quote.
Maybe this person is using the GSL395 for a stand-alone low-pressure N2O fuel system? The Walbro GSL395 is a low pressure pump for carburetor applications.
Perhaps this person was thinking of Racetronix / Lonnie's Performance dual in-tank pump systems which are fully PnP. With upgraded lines they can support 1000RWHP.
To Fuel system help?
