Ls1 -> ls2
Old Oct 22, 2010 | 09:45 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default Ls1 -> ls2
I am almost ready to switch over to a fresh forged LS2 402.
Need some help with what fits / doesn't fit in LS1 to LS2.
Do I need a new oil pan or will my LS1 pan fit the LS2?
Do I need any new/different brackets for things like water pump / alternator / A&A SC currently on LS1?
Is there a extension required for the knock sensor - seems I heard they are mounted in different places on LS2 vs LS1?
Will the clutch / LS1 bell housing mount ok with the "old" style torque tube - to the new LS2 engine?
I have changed the intake manifold years ago to LS6 on the old LS1 engine - will that intake plenum work on the LS2 without issues?
Thanks for you help!
Old Oct 22, 2010 | 09:56 AM
robert miller's Avatar
robert miller
All will work just need some new sensors is all. I did the same thing from LS1 to LS2 block..
Old Oct 22, 2010 | 10:15 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Knock sensors
Knock sensor relocation harness from Caspers sold at SDparts.com (scoggin dickey)
LS2 timing set
LS2 timing cover with sensor.
Cam sensor relocation harness from sdparts.com
Valley cover plate
Everything else will go fine.
Old Oct 22, 2010 | 10:23 AM
Slow Z06's Avatar
Slow Z06
keep in mind if you do this and it starts but wont run, swap the outer 2 wires on the cam sensor relocation harness.
Old Oct 22, 2010 | 04:53 PM
racerrob333's Avatar
racerrob333
and u got to do a little gridding on the block
Old Oct 22, 2010 | 05:57 PM
a/c man's Avatar
a/c man
intake valey cover too!
Old Oct 22, 2010 | 06:50 PM
BLOWNBLUEZ06
Just updated mine. :o
To Ls1 -> ls2
