Are FI cars more sensitive to weather temp changes?
Old 10-31-2010, 01:47 AM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Default Are FI cars more sensitive to weather temp changes?
With the heat caused from boost being a major factor in the computer adjusting timing, I'm wondering if an FI car is more sensitive to weather temperature changes than an N/A car.
Also i'm curious if the boost temp is directly proportional to ambiant air temp or if there is a multiplying factor. (assuming light ~6psi boost)
Old 10-31-2010, 11:35 AM
396375's Avatar
St. Jude Donor '08-'09
IMHO I would think that the FI car would be less sensitive to weather with the inter cooler and meth bringing the inlet temps down to a certain level.The blower or turbos are going to heat the incoming air no matter what the temps are outside.Case in point.I have put ram air systems on 11 second or slower GNs.They don't really react to the change.As far as the turbo goes when it's up to full boost it turns cherry red.It's like a blast furnace and even if you shot icicles, into the inlet the air is going to be very hot coming out the compressor outlet.The temp spread between the outside ambient air will be much more then the spread of the temp of the air coming out of the turbo before the intercooler.
Old 10-31-2010, 12:47 PM
Blow Torch
Blow Torch's Avatar
Depends on whether or not you're SD tuned. The Maf will help adjust fueling, making adjustments for temp. I ran out of MAF, so I had to go SD. There is no temp adjustments. Whatever temp you tuen it at is the temp it will run best at
As for as performance, cooler air is denser air, so it WILL make more boost= more power, on cool mornings.
Old 10-31-2010, 01:38 PM
TheRadioFlyer
Supporting Vendor
what is "SD tuned"?
Old 10-31-2010, 04:54 PM
Blow Torch
Blow Torch's Avatar
Originally Posted by theradioflyer
what is "SD tuned"?
Speed Density tuned
It flows too much for my MAF to read, so I had to go Speed density. It eliminates the MAF, which normally compensates for warmer or cooler air.
Old 10-31-2010, 04:59 PM
TheRadioFlyer
Supporting Vendor
Speed Density tuned
What boost are you running?
Old 10-31-2010, 05:15 PM
Milan
Milan's Avatar
Definitely if you are speed density.
SD works great for those people at sea level...not so great for people who live near mountains
Old 10-31-2010, 05:39 PM
Blow Torch
Blow Torch's Avatar
Around 10psi
Just added 100% meth and a few more * timing, so I'm in the 700rwhp range.
To Are FI cars more sensitive to weather temp changes?
Quick Reply: Are FI cars more sensitive to weather temp changes?
