Winter Projects
Old Nov 24, 2010 | 09:19 AM
robert miller's Avatar
robert miller
Originally Posted by BLOWNBLUEZ06
Ok F/I friends, I'm wondering what you have going on for the winter.
After I finish building and tuning GolfinZ's motor, I have one more (Brandon619's old car) that I'm going to upgrade to the TR6060, 09Z06 diff, cradle and a Mcleod RXT from Byunspeed. Then a 3-bar tune and new Alky pump.
Once those 2 are complete, I'm changing my exhaust to something a little quieter. A nice Magnaflow setup. No matter what I put in, I had to cut and weld to get over the newer trans, diff and cradle. I already TIG welded some V-band flanges on and fit everything together, so I'm just waiting on the rest of my toys. I ordered a brand new ZR1 transmission from Dallas Performance and am waiting on that. As many of you may have read, I am having to work out an issue with the torque tube. I got the new bearings and the slinger ring in. Just need the new couplers and they'll be here tomorrow.
I also did a 4" intake pipe and will be spraying meth straight into the blower. I am cleaning up the existing meth nozzles with a new pipe from A&A.
I have made quite a few shields for other members that prevent the breaking of the serpentine belt from ripping the drain line apart, but as one might guess, I didn't have one on my car yet, so I fabbed one up for my 10-rib.
I took a little design that Arun shared with me and tailored it to my suit my application a little better. I had a good friend we call "Doc" machine some really cool parts for me to make it happen. I got the new bracket from A&A and welded up the tensioner and placed a custom double bearing idler on it that Taylor at Dallas Performance designed. I installed a 10-rib IW O.D. balancer and Doc is building me a custom 2.65" pulley that I designed. If everything holds, it should make 1Krwhp and be quite fun. Once I get it together, you guys know I'll post up #'s and pictures.
Hop in here and tell us what you got going on.
looks like you have a good month are so of work good luck hope it goes easy on you man...The car sounds like it will really be hooking up for you. Post the pic,s man.
Old Nov 24, 2010 | 09:31 AM
Neil B's Avatar
Neil B
This winter, I'm freshening up my 408/F1R combo in my Corvette with a little more compression and cam, new bearings, lifters, etc. I'm also building an old-school 13.5:1 solid roller 377 for another project.
Old Nov 24, 2010 | 09:34 AM
02402ramair's Avatar
02402ramair
Thinking about selling everything and go back close to stock!
Old Nov 24, 2010 | 09:39 AM
TracyRR's Avatar
TracyRR
hey bret, not exactly a winter project but i took your recommendation and ordered some toyo r888's! 335/30/18.... so hopefully i will be able to feel more than 11 - 12 pounds on the street. I'm replacing some very hard kdw's, 335/30/18. Can't wait!
Old Nov 24, 2010 | 11:37 AM
black98c5's Avatar
black98c5
Pulley down and see what this F1C can really do.
Old Nov 24, 2010 | 11:49 AM
Its Bruce's Avatar
Its Bruce
Trying to get my ACT twin to work properly, as it has decided to not disengage all the way. Once that's fixed, fuel rails, return-style regulator and bigger fuel pump go in.
Old Nov 24, 2010 | 12:30 PM
chris@sfcc's Avatar
0chris@sfcc
Former Vendor
motor is getting torn apart for a little 'freshen up' after the texas mile incident. We'll see how much money I end up spending on the "as long as we're in here" and "might as well do it now"s that creates.
Old Nov 24, 2010 | 12:57 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Wow! I knew there was some really cool stuff going on here. Glad everyone is chiming in. Post pics in here as you get them. I'll do the same.
Old Nov 24, 2010 | 01:14 PM
black turbo c5's Avatar
black turbo c5
I didnt really want a winter project but i got one now . I got a cracked block so i'm building a new motor and going to a ttix kit the stock motor lasted awhile on the boost but it finally let go.
Old Nov 24, 2010 | 01:20 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Assemble and install my LSX 454 engine and see if I can get 1,000 RWHP from it!
Last edited by clif; Nov 24, 2010 at 04:28 PM. Reason: OOPS! There was an extra ZERO!
Old Nov 24, 2010 | 02:14 PM
TT Z06's Avatar
TT Z06
Old Nov 24, 2010 | 04:08 PM
BLOWNBLUEZ06
OOOOhhh. So you're the one!?! You won't regret it. I got some video of that car and rode around in it while tuning. You're in for quite the treat my friend!
Old Nov 24, 2010 | 04:10 PM
  #33
BLOWNBLUEZ06
Originally Posted by clif
Assemble and install my LSX 454 engine and see if I can get 10000 RWHP from it!
Either you have an extra zero in there, we're all in for a big surprise or you're in for a big disappointement.
Old Nov 24, 2010 | 04:14 PM
  #34
golfinz's Avatar
golfinz
Old Nov 24, 2010 | 04:18 PM
  #35
clif's Avatar
clif
No extra zero! I am building a killer engine that can handle 25+ PSI of blower.
Old Nov 24, 2010 | 04:20 PM
  #36
golfinz's Avatar
golfinz
One millliiioonn horsepower
Old Nov 24, 2010 | 04:23 PM
  #37
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
You do realize that you posted 10,000 hp, correct?
To Winter Projects
Old Nov 24, 2010 | 04:26 PM
  #38
Corvette-Chris
St. Jude Donor '08
I got my new LS2 oil pan in today and really want to get started on some work, but I have a guy in town with a A&A blower C6 car that has been wanting to run. Maybe Ill get started later this weekend, but if not, Ill start in a couple weeks. I just plan on dropping the front cradle a few inches in order to pull the batwing out and replace with the LS2.
Old Nov 24, 2010 | 04:29 PM
  #39
clif's Avatar
clif
Yall win! I DID have an extra zero!
Old Nov 24, 2010 | 04:39 PM
  #40
SVTLOL's Avatar
SVTLOL
I highly recommend you consider the 6-point from Wolfe with the removable door bars. They also have billet aluminum caps to put on the ends so it looks clean. You can powder coat those ends for a stealth look too. Let me know if you need pics. They always run a wicked sale at the end of the year, so go to their site and check. This is close enough for them to be running it I think.
Thats what i have in my car love it gives it that race car feel .
