When do I need polyurethane couplings?
Old Jan 6, 2011 | 11:26 AM
69Nova's Avatar
69Nova
Default When do I need polyurethane couplings?
I just put on a a&a charger kit at 8psi and cam longtubes ls6 intake .. Car will be getting dyno maybe next weekend I'm hoping between 500-550rwhp.. I have bought a stage 6 transmission with triple disk converter. All from rpm. My question is should I buy new ones fromrpm when I swap in trans or will sock ones work? I don't care eith way but I don't know if stock will be fine or that will be limit for them. Anyone care to take a stab at this?
Predictions of how much she should make anyone??
.581 .588 220 228 116+3 lsa
a&a @8psi
longtubes gull exhaust
ls6 manifold
built trans and converter
3.15 rear gears
maf tune
Old Jan 6, 2011 | 12:06 PM
corvettebob1's Avatar
corvettebob1
I would do the coulpings while you have the trans out if you have the extra cash.
And I have to ask why your doing the maf tune since it'll max out ~500rwhp.
And with your setup you better be north of 600rwhp and spray meth.
Old Jan 6, 2011 | 02:11 PM
69Nova's Avatar
69Nova
Is there a reason why it will max out at 500 rwhp on the maf tune... I guess that I am going with a maf tune because I don't kno much about speed density tunes first of all.. Secondly I like in maine at sea level literally on the ocean so I want to make sire if I drive it into the mountains to fool around I can and won't have worry about tuning issues. And I want this to be a complete daily driver and don't want to keep having to buy meth online as where I live it is not redialy available. If I want to go for a 500 mile drive I want to just get in and not having to bring extra meth (that's the main reason).. My buddys roush had meth and when he's out he can't drive it so that isn't appealing to me..
Why is maf tune good for 500 rwhp?
Why is speed denisty tune so much better?
My main goal is to get into the car and drive it wherever I wanna
Old Jan 6, 2011 | 02:21 PM
Mike04's Avatar
Mike04
I would upgrade while you have the tranny out, much easier that way.
Your MAF is limited in how much airflow it can relay on to the PCM. The amount of air needed to make (using 500rwhp as a round number) could be all the airflow the MAF can relay due to voltage limits of the MAF. So once the airflow reaches the max flow for the MAF, it doesn't really do anything to adjust the PCM from that point up in HP. That is when you add fuel based on rpm.
There is a thread in this section that goes a little more into the MAF/ SD tuning debate. My car is SD tuned and I'll never go back to a MAF tune....
Old Jan 6, 2011 | 07:33 PM
69Nova's Avatar
69Nova
That's very good input straight forward and to the point.. How come its such a huge difference in price between the two?
And as for the couplings I will be ordering them thanks again guys
Old Jan 6, 2011 | 09:15 PM
Chris Stewart's Avatar
Chris Stewart
I'm running a MAF tune and stock GM couplers, thru A4 for 2 years over 650rwhp. I go more by the rule of don't fix what aint broke. After 2 years I just pulled the torque tube and inspected the GM couplers, they were good as new. Haven't had a reason to update my MAF tune.
Old Jan 6, 2011 | 09:37 PM
leo12's Avatar
leo12
Iam not sure who is telling you that maf tune is only good for around 500 hp, 98 vette here d1 supercharger over 760 rwhp with a maf tune and still have more room to play with.
I think that clears things up a bit
Old Jan 6, 2011 | 10:11 PM
69Nova's Avatar
69Nova
Alright thanks seems there is a lot of discussion and opposing views between maf and sd tunes. I will be going with a maf as of now.. Numbers will be in next week with what it makes without meth... Not running meth what would you guys think would be a good a/f ratio to be safe
Old Jan 6, 2011 | 10:16 PM
Chris Stewart
A/F about 11.5:1 is in the ballpark. Here's one scenario (as I understand it). Let's say you do a SD tune for 20psi and make 1000rwhp. Then you realize you can't plant the power on the street, and turn down the boost to 10psi. The SD tune will adapt the fueling and maintain proper AFR.
With a MAF tune, the airflow range of the sensor is maxed out somewhere over 500rwhp. The upper RPM fueling curve is hard coded to RPM, so it doesn't adapt if the boost goes up/down. So if you do a MAF tune for 20psi then switch to 10psi, it goes rich.
Old Jan 6, 2011 | 11:39 PM
wilson34's Avatar
wilson34
Correct, I don't know why some don't do the SD tune while they are having the car tuned. It's an extra expense but well worth it in the end.
To When do I need polyurethane couplings?
