ATI Cog setup
Old Jan 28, 2011 | 06:09 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Default ATI Cog setup
Ok, I picked up a F1, ATI cog kit and bracket off Fleebay the other day. Good deal and was looking for a headunit upgrade anyway, just wasn't sure I wanted to stay w/ Procharger.
So the cog kit has me thinking, what is everyone's stance on these? I think I have only seen 3 guys using them. It is the crank pulley, powersteering, alt, and head unit pulley.
I already have a Flip-Drive, so I would only be using the crank pulley and headunit. I am not goin to spinning that F1 very hard, so the cog may just be overkill.
Input?!?!?!?
Old Jan 28, 2011 | 07:09 AM
YeloFevr's Avatar
YeloFevr
do you need to move rack forward with that crank pulley?
Old Jan 28, 2011 | 07:25 AM
C5kid's Avatar
C5kid
St. Jude Donor '12
I don't believe so. It uses a 30mm cog belt, which is roughly 1.18" wide. A 8 rib serp. belt is 1.10" top width from what I could find.
Old Jan 28, 2011 | 08:32 AM
Chris@HPS's Avatar
0Chris@HPS
Former Vendor
If you purchase the flipdrive kit then you can have your own dedicated cog belt running the blower. However, under normal driving conditions and some wot throttle the cog worked well, Hit the rev limiter one time and the belt will break. I ran the cog setup for appx 6 months, and just switched over to a 10rib setup.
Chris
Old Jan 28, 2011 | 08:44 AM
wilson34's Avatar
wilson34
Chris did you swith to 10 rib on the F2 setup?
Old Jan 28, 2011 | 09:07 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Chris
Converted from 8 to 10-rib here. Hoping to test it out soon.
Old Jan 28, 2011 | 09:21 AM
C5kid's Avatar
C5kid
St. Jude Donor '12
Chris
That is what I was afraid of. I heard that the cog belts and rev limiter don't get along.
Old Jan 28, 2011 | 09:46 AM
Chris@HPS's Avatar
0Chris@HPS
Former Vendor
Yes I did. No one made a cog belt in kevlar in the length I needed, therefore, I kept breaking belts. At the Holley LS event, guys were breaking 50mm cog belts as well, so for what I do with my vette, the 10 rib will work just fine.
That is correct!
Chris
Old Jan 28, 2011 | 09:52 AM
wilson34's Avatar
wilson34
How is the 10 rib working for you Chris, any runs at the track with it?
Old Jan 28, 2011 | 12:28 PM
Chris@HPS's Avatar
0Chris@HPS
Former Vendor
No sir, I just got the belt in today. Installing in a few, then I will be able to give some feedback.
Chris
Old Jan 28, 2011 | 02:46 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
You'll need a Big BOV, like a Big Red, some solid motor mounts will help and maybe even a strut brace for bracket flex.
And makes sure the belt is far away from any fuel or coolant lines-the cog belt will shear right through that.
If your car's an auto you have a better chance to get it too live, stick car not so much.
I had it on my Novi 2000 back in 96, but the cog pullies were around 50mm wide.
Old Jan 28, 2011 | 02:59 PM
C5kid's Avatar
C5kid
St. Jude Donor '12
I am not running the cogs. Procharger said I need a 4.75" pulley to keep my boost down around 13#. I don't think w/ that large of a pulley and a Flip Drive I am goin to have slip issues.
So.... anyone intrested in buying a cog set? Sell it for a good price
To ATI Cog setup
