HELP! Snow Meth system not working!
Old Jan 30, 2011 | 12:12 PM
spoon98hatch's Avatar
spoon98hatch
Default HELP! Snow Meth system not working!
Ok so my meth system stopped working. Im so frustrated right now because i cant figure out why.
Heres what Ive done so far.....
-Isolated pump applied 12v- pump came on-eliminated possibility of bad pump ground or bad pump
-Checked MAF signal wire to controller for Voltage- has voltage
-Checked ground for controller unit itself- it was good but i re did it anyway
- Ive literally checked everything I can check on this system and from what ive gathered it boils down to being a bad control unit, but before i condemn it Id like your opinions. Thanks
Old Jan 30, 2011 | 01:09 PM
joshtownsend's Avatar
joshtownsend
i believe that the maf input signal going to be 0-5 volts. Find out for sure what it is , then add it to the controller box and see if you get 12 volts or a closed circuit relay out to the pump. There is really nothing to it.
Old Jan 30, 2011 | 01:14 PM
dsmlights's Avatar
dsmlights
did you press your test buttom and see if the pump runs ? Does the controller have power ?
Old Jan 30, 2011 | 01:21 PM
Its Bruce's Avatar
Its Bruce
How do you know the pump came on? By sound or did it actually flow? And if it did flow, was it downstream of the filter (if there is a filter)?
Old Jan 30, 2011 | 01:37 PM
spoon98hatch
Yeah the pump came on and flowed- i disconnected the line and had it flow into a jug.
Yes the controller has the 12V fused IGN source. Ill check again but electrically as far as wiring goes everything is sound from what i can tell.
Old Jan 30, 2011 | 01:41 PM
spoon98hatch
Yeah the MAF signal voltage range is 0-5v. I have that varying voltage while the car is on when i tested the wire leading to the controller. Problem is somewhere in between where the MAF signal goes into the controller and the 12v source to the pump- its not switching on like it should. Which again leads me to believe i have a bad controller unit.
Thanks for the suggestions so far guys! It helps to have others brainstorm with me- im about to lose my mind
Old Jan 30, 2011 | 02:22 PM
Milan's Avatar
Milan
Our MAF doesn't output in volts (like a Ford MAF) it reads in Hz, you need to boost reference the Snow kit instead
Old Jan 30, 2011 | 04:36 PM
spoon98hatch
Hmm well the kit worked fine for like a month- went through one gallon of methanol before it stopped working.
Old Jan 30, 2011 | 11:04 PM
dsmlights's Avatar
dsmlights
WELL IF YOU PRESS THE TEST BUTTON THEN THAT PORTION of the controller is working. Take the soruce wire which is the one that suppose to be connected to the map sensor and connect it to 12 v . If the pump turn on then it is working correctly.
Old Jan 30, 2011 | 11:24 PM
spoon98hatch
This kit doesn't have a test button. Also I did that already- applied 12v to the yellow Maf wire and nothing happened. This is a Snow kit
Old Jan 31, 2011 | 09:53 AM
dsmlights's Avatar
dsmlights
I am sorry I was thinking it was the Alcky control lol
Old Jan 31, 2011 | 11:45 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Which is what he should have and wishes he had.
Old Jan 31, 2011 | 11:53 AM
robert miller's Avatar
robert miller
This one that you have is it like the Alcky, if water gets into the motor part of the unit it will lock it up and no more workey.
Old Jan 31, 2011 | 11:55 AM
BLOWNBLUEZ06
I belive that's the way all the pumps are, but his pump seems to be working when the controller is bypassed and voltage is throw directly to it.
Old Jan 31, 2011 | 09:54 PM
spoon98hatch
Yeah I know- Im about to just order a new kit. I didnt get a chance to call snow- but im wondering if the controller has an internal fuse...
Old Jan 31, 2011 | 11:58 PM
Milan's Avatar
Milan
BTW spoon what did you have done to your honda? I had a 93 EG myself, and a EK couple later that was stolen
Old Feb 1, 2011 | 08:13 AM
spoon98hatch
I had a 98 hatch- swapped- simple- clean.
Then a 00 Ex coupe- single cam turdslow
And this when i felt like getting crazy...
I was young lol......
Old Feb 1, 2011 | 10:57 AM
golfinz's Avatar
golfinz
See the ECS GP a few posts above yours. Now is the time to ditch the snow kit
To HELP! Snow Meth system not working!
