help with fuel setup
Old Jan 31, 2011 | 10:16 PM
froman's Avatar
froman
Default help with fuel setup
Hey guys , putting a p1 on pretty soon on my stock shortblock ls1. I've got a g5x1 cam and right now stock fuel setup. I dont plan to go anywhere over 600hp, what should i do for fueling? single walbro and some injectors? what size injectors would hold 550ish rwhp?
Old Jan 31, 2011 | 10:24 PM
MyEBc5Z's Avatar
MyEBc5Z
I'm putting a p1 on my ls6 and I'm gonna be using 60lb injectors, walbro 255 fuel pump, racetronix harness, and a kenne bell bap. I'm hoping it's enough for about 640rwhp with meth and a blower cam.
Old Jan 31, 2011 | 11:12 PM
Milan's Avatar
Milan
What year is your car?
Old Jan 31, 2011 | 11:22 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Simply because there is no significant difference in cost or driveability, I would get the 83lb Siemens Deka injectors. That will give you the flexibility when you change your mind. A 255 and BAP should get you there for supply.
Old Jan 31, 2011 | 11:37 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Agreed. I've changed injectors 3-4 times now and Its more convenient to step it up from the start. Also, you will be good with a Walbro, KB BAP and Racetronix harness.
Old Feb 1, 2011 | 03:18 PM
froman's Avatar
froman
ive got a 00 frc. Dont want to go over 550-600rwhp cause the motor just wont take that power. I dont mind stepping it up when and if i decide to build the motor... but even if i do im prolly gonna spray it with a standalone.
Old Feb 1, 2011 | 04:24 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
60lbs, 255, Hotwire, & KB-BAP, got me to 615 then the fuel pressure would steadly drop from 60lbs to 51lbs.
Old Feb 2, 2011 | 02:13 AM
Blown_2001Z06's Avatar
Blown_2001Z06
I will have 42lbs injectors and a kenne bell bap available in about a week. I am putting a bigger supercharger and a bigger fuel system in mine. Let me know if you might be interested. I was running 580rwhp so this is exactly what your looking for.
Wesley
Old Feb 2, 2011 | 04:22 AM
jobberone's Avatar
jobberone
jobberone
Sixty or so will do the job but I agree with Bret. You can grow into the 83# injectors and the duty cycle on them will be much less than 60s. A Walbro and BAP will do nicely for now. You will need a return line if your car doesn't already have one. You can always add another external pump if you change motors and setup and need more fuel. You should add a boost referenced regulator IMO. A good vacuum one will do nicely. 550-600HP is relatively safe in a stock motor with a good tune. I would always add meth to a boosted stock motor for safety regardless of boost as you will keep cylinder pressures and heat down esp in the summer. Your engine will live longer. You should consider a bigger radiator.
Old Feb 2, 2011 | 08:10 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I have a set of 60# and a set of 83# sieman deka injectors.The 83's are like new,Less then 30mi.The 60's are a few months old.Let me know if you are interested I'll pm a price to you....................Paul
Old Feb 2, 2011 | 11:37 AM
Milan's Avatar
Milan
Return line and a boost referenced regulator will be important
Old Feb 3, 2011 | 09:28 PM
SBCGENII's Avatar
SBCGENII
a 255 will run out before the 60lbs do. No matter what injector you go with the most important thing is getting all the info for the injector.
To help with fuel setup
