dynotune lean shut down switch
Old Mar 16, 2011 | 12:14 PM
Badd LS6's Avatar
Badd LS6
Default dynotune lean shut down switch
does anyone use this with their nitrous setup?? im thinking about ordering one. i need my kit to be as safe as possible
Old Mar 16, 2011 | 12:17 PM
Blow Torch's Avatar
Blow Torch
I had one, but other than doing a "safety test" I don't really know if it worked (thankfully)
You will need a wideband to hook it up with. A narrow band (stock)will not work.
Old Mar 16, 2011 | 12:21 PM
Badd LS6's Avatar
Badd LS6
hmm i do not have a wideband
Old Mar 16, 2011 | 03:52 PM
Blow Torch's Avatar
Blow Torch
It's worthless without one. The narrow band is not going to reliably recognize 13afr, 11afr etc., so you will not be able to accurately set it for cut off.
I had mine set to shut off at 12.0 and was jetted to run 10.5-11.
To dynotune lean shut down switch
