Procharged C5 Drivetrain Upgrades
get the C6 Z06 30 spline main shaft for the tranny while it was
being redone and get the C6 Z06 diff/subframe. I just replaced
my diff(spilt case) and broken main shaft with a 30 spline. I did
not go with the C6 Z06 case/subframe because I don't plan on
going back to the track, but I did go with the re-splined pinion,
c6 z06 pinion carrier, output shafts,carbon clutch packs and have
an ecs brace and tranny already had level 5 upgrades done.
Call Rick at RKT56.COM He is in Maryland and really does great
work on C5/C6 tranny and diff upgrades.
Good luck to you,
Wayne
Good luck to you,
Wayne
If you are going to look at the point better safe than sorry. But again I am thinking you should be fine only pushing 700 rwhp. With only the left side in it. I am getting all the stuff up now to do the C6 Z06 cradle chg out in my car now but I am pushing 273 more at the rear wheels than you are. And also going from Level V to a Level VII A4 trans from RPM.... Robert
