Alkycontrol question?
Old Mar 26, 2011 | 11:03 AM
chargedc5's Avatar
chargedc5
Default Alkycontrol question?
ALKYCONTROL QUESTION?
When you push the test button on the controller should the little light on the gauge pod show green. I had mine hooked up and it shows red when the test button is pushed???
thanks
Old Mar 26, 2011 | 01:20 PM
corvettebob1's Avatar
corvettebob1
Yes that's what it should do, if you turn the gain all the way up and have the engine running it will turn green.
Old Mar 26, 2011 | 01:34 PM
corvette8189's Avatar
corvette8189
just shows red, doesnt show green when u hit the test button. when your full throttle it should be green though
Old Mar 26, 2011 | 01:58 PM
PMPNSEZ's Avatar
PMPNSEZ
Mine flashes red when test is pushed. When I'm full throttle and my preset boost is hit the light will turn from red to green
Old Mar 26, 2011 | 02:06 PM
Its Bruce's Avatar
Its Bruce
Do yourself a favor and disconnect the hose at the nozzle, point it into a can or otherwise away from the car and hit the test button to ensure you're getting flow.
Old Mar 26, 2011 | 02:55 PM
chargedc5's Avatar
chargedc5
Thank you guys...can you put the nozzle before the maf, I done have any where to put it otherwise?
Old Mar 26, 2011 | 03:00 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
thanks
Who is Tuning your car, I am putting an Alkey kit on next week? I live in Northwest Indiana 40 min from Chicago!
Old Mar 26, 2011 | 03:09 PM
PMPNSEZ's Avatar
PMPNSEZ
That's how mine is setup!!!
Old Mar 26, 2011 | 04:17 PM
chargedc5's Avatar
chargedc5
pm sent
Old Mar 26, 2011 | 04:26 PM
Steve@TunedbyFrost.com's Avatar
0Steve@TunedbyFrost.com
Former Vendor
I regularly travel to Fort Wayne IN (every 2-4 months) for tuning and have much methanol experience...
Old Mar 26, 2011 | 04:39 PM
Blow Torch's Avatar
Blow Torch
I would install the nozzle after the MAF. I located my IAT RIGHT before my TB so I could watch the effect of the METH. Basically, the nozzle should be between the MAF and the TB (and IAT)
Old Mar 27, 2011 | 12:36 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Mine turns green - and it is set at 3 1/2
Thanks,Matt
Old Mar 30, 2011 | 09:21 PM
Julio's Avatar
Julio
When the kit wakes up.. meaning you go into boost or hit the test button.. the LED will light up red. Once the line pressure hits 50 PSI of liquid pressure, the LED will change to green.
When you press "test" you only send 3.5-4.0 volts to the 12 volt pump. So it does a low pressure test. 3.5 volts on a twin nozzle setup may not reach 50 PSI liquid pressure. But it flows the liquid non-the less.
Cars with twin nozzles may/may not go green when hitting test. This is because of the orfice size on the nozzles. Example you unhook the hose from nozzle, it will never go Green.
Liquid should flow through nozzle when hitting the test button. Messing with the controls may alter this.
What I do.. is watch my wideband gauge.. as i'm driving i'll push the button and as soon as air fuel drops a little.. its lock and loaded. When I go WOT.. i'll see it change from red to green. Thats it.
Cars without a wideband.. you'll notice the motor load up.
If at WOT it doesnt go green... pull out of the throttle. Something is wrong.
Hope this helps
Old Mar 4, 2012 | 06:58 PM
hiperf454's Avatar
hiperf454
Well I cant hook mine up because I have this black box with 4 wires coming out it is suppossed to hook up to the MAF and not the MAP. There are no wiring instructions for this. I could use some help. Thanks
Old Mar 4, 2012 | 07:49 PM
Julio's Avatar
Julio
4 wires
Pink
Yellow
Black
Green
Connect pink to pink on MAF
Connect yellow to yellow on MAF
Connect black to black on MAF
Connect green to green on alcohol controller
Old Mar 4, 2012 | 10:04 PM
hiperf454's Avatar
hiperf454
Originally Posted by Julio
4 wires
Pink
Yellow
Black
Green
Julio,
You are the man!!! You know how long I bought this and its been mounted the same weekend and then........ I locked up it kept showing the green going to the MAP and you and I talked about my Mag car did not need the map. I really appreciate you sir.
To Alkycontrol question?
