bov question ??
Old Apr 19, 2011 | 12:20 AM
avenger88's Avatar
avenger88
Default bov question ??
just wanted to know what is a louder bov and more in particular which one will dump more. Kinda make like a fire hose noise all the time. Right now on my car I have a procharger red valve with a d1sc making 15 lbs. of boost and it sounds all right. My father on the other hand has a vortech on an f1r set up making 26 lbs of boost which sounds omg unreal. Just like a fire house / street sweeper all the time. Is this more due to the bov or the different blowers and boost #s. also both sound different when both cars are in vacum. Should I switch to a vortech or just loosen my procharger valve all the way?
Old Apr 19, 2011 | 12:45 AM
Milan's Avatar
Milan
Loosening it all the way won't help, it should already be open at idle. If you cam tighten it all the way to the point of it not opening at idle and then back off some that should help.
Old Apr 19, 2011 | 12:51 AM
avenger88's Avatar
avenger88
ok got it so for the like dumping fire hose noise in vacum tighten it then back off alil?
Old Apr 19, 2011 | 12:58 AM
Milan's Avatar
Milan
The tighter it is the louder it will be
Old Apr 19, 2011 | 01:08 AM
avenger88's Avatar
avenger88
sickkkk. . you think if i tighten it i gotta get it retuned? also itll still dump and not just be really loud under boost right
Old Apr 19, 2011 | 01:10 AM
avenger88's Avatar
avenger88
dude also i saw you replied on some1 elses thread that a disc could pull 800rwhp. i got a forged 347, trick flow 215s, a&a stage 2 blower cam, n disc esc 8rib set up with twin intercollers and meth. im right around 700rwhp but going lean so doing fuel system now. you think if i did a fmic and upped boost alil i could hit 800rwhp? or get a ysi
Old Apr 19, 2011 | 10:12 AM
Milan's Avatar
Milan
I don't think a ysi is that much bigger than a d1sc but yeah definitely get one
No you won't need a retune if you adjust your BOV, but just know it might not make a huge difference...but that procharger vavle is pretty loud
To bov question ??
