METH better than E-85. Dyno comparison INSIDE!
Old Apr 22, 2011 | 03:29 PM
stainless40cal's Avatar
stainless40cal
Kinda figured something was up with the motor. Didn't really make sense otherwise.... Let us know what's up with the motor.
Old Apr 23, 2011 | 07:26 PM
dykz34's Avatar
dykz34
Originally Posted by dsmlights
well guys I went back to the dyno on the pump and meth tune. So e85 is not that bad at all It actually made more power than meth+pump. I think there is something wrong with my motor probably because with pump meth now it only made 570/460 ... I might have a dead cyl or something like that. I will post the dyno later this week so you guys can see the diff. Only thing I changed was the fuel, same dyno and weather conditions.
So it appears that you made MORE power on E85? Hope everything is well with the motor - this thread title is misleading now....
<--- runs E85
Old Apr 25, 2011 | 06:39 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Here is the deal with E85- Its main advantage is the cooling effect. You need to tune on LA, not AFR. AFR is really inaccurate. Shoot for a .85-.87 lambda, and you will see the gains. If you calculated that to AFR on gas, it would be in the 13s.
You will never see the knock sensors go off on E, as itll melt stuff before it pings, and really, itll just lean misfire first before it hurts stuff.
I have a lot of experience with it, and its great stuff, but at your power level, its not really a big gain.
Also, the fuel % doesnt vary much at all. The anti knock qualities of E70 vs E85 are nearly identical. The only thing that changes is the total fueling of the added or removed gas vs ethanol content.
Keep at it, youll get it!
Louis
Old Apr 25, 2011 | 06:42 PM
C5blownz06's Avatar
C5blownz06
I wouldn't tune anyone's car on AFR no matter what they are running fuel wise...EVER. Lambda only...Im really surprised many tuners out there still dont change the stoich table in cars they tune when they know there is ethanol in the fuel everywhere now.
Old Apr 25, 2011 | 08:40 PM
Milan's Avatar
Milan
Louis
Yikes...surprised to see such poor advice from such a big shop.
Wideband's measure lambda, they report whatever fuel they are calibrated for.
To say AFR is really inaccurate is not only wrong but a poor use of scientific terminology
Old Apr 25, 2011 | 11:26 PM
Milan's Avatar
Milan
To elaborate a little more on my previous post.
The wideband is always reading lambda, they are calibrated for a specific type of fuel (usually gasoline) and then when lambda = 1 then they report the stoich ratio for that fuel. So for gasoline when lambda = 1 then what you will actually see is 14.68
If your wideband is calibrated for gasoline, and you are running E85, when lambda = 1 it's still going to show 14.68.
Therefore if you want to shoot for .85 lambda on E85 like Louis said, you would target 12.48 as it would be displayed on a gasoline calibrated wideband.
The reason targeting a leaner mixture on E85 is stupid is because of the following:
1) E85 is an oxygenated fuel, you may have heard the saying on gasoline "leaner is meaner", this is NOT true with E85
2) It has been shown that there is no significant HP increase running E85 at 12.5:1 vs 11.5:1 (gasoline calibrated wideband)
3) People have found, however, that running the E85 richer rather than leaner often lets you get away with more timing and thus results in some more power
Hope this helps
Old Apr 26, 2011 | 10:45 AM
Former Vendor
Hope this helps
I read a few of your posts, and you seem pretty new to the modding world?
You also stated, previously,
I don't have E85 tuning experience, just know a lot of people running it from when I lived in Colorado. I don't think leaner = meaner on E85. I think it will make more power the more you can throw in there provided it can combust.
I use a Motec PLM for all of my tuning. I really dont care what an AFR gauge says, I tune in La.
The last 4 months, Ive had a MAJOR role in building 3 supras, all over 1100 rwhp, all on E85, two of which went 8s, one made 1200rwhp.
Ive had my fair share of building, tuning, and racing E85 powered Vehicles. Im finishing up an E85 fueled ZR1 now.
Old Apr 26, 2011 | 11:31 AM
jhester's Avatar
jhester
when you are tuning for e85 you need to only talk in lambda, to consider tuning or discussing AFR (instead of lambda) is only asking for future failure
Old Apr 26, 2011 | 12:07 PM
Milan's Avatar
Milan
I am new to tuning my car aka LSx motors with HPtuners, not tuning completely.
Further more, most shops and tuners are capable of building high HP cars, very few understand the physics/chemistry behind tuning.
At the end of the day, essentially everything about your initial post was wrong.
Here's where you were incorrect specifically:
1) Widebands measure in lambda. For the sake of argument, if you have an AEM wideband, and lambda = 1, then it will show 14.68 on the gasoline setting. It doesn't matter if you have E85, methanol, gasoline, or rubbing alcohol in the tank, the WB will displaye 14.68 when lambda =1.
2) "AFR is really inaccurate", actually your statement is inaccurate.
3) If you calculated AFR of .85-.87 lambda for gasoline that would be 12.478 and 12.771 respectively. So clearly not "in the 13s" like you stated.
So good for you if you tune your own cars, but I wouldn't let you touch mine if it was for free.
Old Apr 26, 2011 | 12:22 PM
C5blownz06's Avatar
C5blownz06
There shouldn't even be any argument afr vs Lambda tuning. If you aint using Lambda then you are still in the backseat.
Old Apr 26, 2011 | 12:24 PM
JustinStrife's Avatar
JustinStrife
This thread just got interesting.
Old Apr 26, 2011 | 12:49 PM
tail_lights's Avatar
tail_lights
Yup
Old Apr 26, 2011 | 03:49 PM
  #33
AZZ-KIKR's Avatar
AZZ-KIKR
Only because I am on the fence with going E-85.
Old Apr 26, 2011 | 04:39 PM
  #34
ysb02's Avatar
ysb02
Big problem is it's *UP* to 10% so your fuel ethanol % will vary during the year.
Old Apr 26, 2011 | 05:29 PM
  #35
Warp Factor's Avatar
Warp Factor
Why does it matter which scale the display is set to (as long as you know which, and know what to do with it)? Either way, it's measuring the same thing.
Louis, why is having the display set to lambda better?
Old Apr 26, 2011 | 06:04 PM
  #36
stainless40cal
Dont be. Search around. Not on this forum but others that have really used this fuel. Its beyond amazing, if you have it at your local stations and are not taking advantage of it you dont know what you are missing. Cooling affects, 105 octane, virtually no detonation even when you **** up. Take a look at some of the big boys and see that they are running it over race gas and getting better results for the money.
Old Apr 26, 2011 | 08:07 PM
  #37
jcosta79's Avatar
jcosta79
I'd let him tune my car for free but he insists on getting paid.
Personally, I can tell you he was able to make my '08 LS3 N/A C6 with a race cam put down 517 RWHP and still make it drive like a ***** cat.
Old Apr 28, 2011 | 10:10 AM
  #38
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
I can't speak for anyone else but I have found the best results with .78-.82 La on E85. I don't think this is unusual or new to anyone.
Louis, did you do the tuning on those Supras? I was told by their owners that Darren tuned all three of them?
Either way, fast cars for sure
Old Apr 28, 2011 | 01:52 PM
  #39
Former Vendor
Hi Taylor, Darin dyno tuned them, we track tuned them. It went 160 in florida after PRI at .87 and 159 in Texas
Pistons and plugs looked great on tear down.
