How much boost?
Old Apr 26, 2011 | 12:43 AM
reactor2's Avatar
reactor2
Default How much boost?
Can someone give me an idea of how much boost I can expect with the following setup?
Procharger p1sc stage 2 kit
3.85 cog
Dart pro 1 205cc (10.8-11:1 cr)
228/232 .571/.573 112
Fast 78
Ported BBK 80mm TB
BBK shorty headers
Ti exhaust
Old Apr 26, 2011 | 12:58 AM
corvette8189's Avatar
corvette8189
no clue but 10# seems the going #
Old Apr 26, 2011 | 02:17 AM
reactor2's Avatar
reactor2
I assume 10psi, pump gas and no meth is a bad idea with a static cr of 10.8-11.1 (I forget exactly what I calculated the cr to be but I'm running the LS2 head gaskets)?
If I wanted to run pump gas and no meth what is the highest psi I should run?
Old Apr 26, 2011 | 07:27 AM
blownnastyc5's Avatar
blownnastyc5
10 is always the safe number I hear..... but with all things, eventually something will break if not built for it!
Old Apr 26, 2011 | 10:32 AM
C5blownz06's Avatar
C5blownz06
10 may not be a safe number at all depending on the tune. Ive seen built motors go with 7 psi.
Old Apr 26, 2011 | 10:53 AM
blownnastyc5
anything will grenade with a tune hell bent for destruction....
Before this goes down the wrong path, if you plan to mod and hotrod something, plan to spend money and work on it some more. It comes with the territory if your gonna drive it like you built it too.
Old Apr 26, 2011 | 12:07 PM
reactor2's Avatar
reactor2
Is 10psi really possible on pump gas/no meth with a 10.8:1+ cr...even with a safe tune?
Old Apr 26, 2011 | 12:56 PM
corvette8189
its possible, but how long is it going to last is the question. u should really consider meth
Old Apr 26, 2011 | 03:27 PM
blownnastyc5
18K miles with blower set up, and most of them were earned miles. Although I now have METH, its really good insurance and a bit of power to be gained.
Old Apr 28, 2011 | 08:20 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
without meth, a compression ratio that high and 10Lbs of boost your asking for trouble I dont care how good of a tune you have.
To How much boost?
