Traction mods help..
I currently am putting down 531 RWHP and 450 TQ. I plan on getting a retune real soon, adding meth, and possibly going from 8lbs to 10lbs of boost on my novi2000 from ECS (need some help deciding this as well).
I am running 305/35/18 nitto 555R's in the back and I'm using the factory Z06 rims. I can't hook up at all with these tires - maybe they're old or just not sticky enough - either way, I want to be able to hook up when I add the additional mods to my car.
So I'm torn between two different options here.. Obviously one is MUCH more cost effective but I'll only go this route if it will be able to hold the power (somewhere around 575 - 600 RWHP ).
1. Keeping my current 18x10.5 OEM Z06 rims and getting some 305/35/18 ET Streets for the rear - only $305 a tire.
2. Going all out with some 18x12 CCW C14's, fender flairs, and a 345/35/18 tire. This route will cost me $5000+ .
Will 305 ET streets be able to hold the power without spinning? Is there a better option tire for what I'm looking for?
Will option number two be overkill? I know it will look awesome, but I'm happy with what I have now so if I can hook up from a roll in first gear and not spin I will save my $4500.
Any help will be appreciated! Thanks guys.
And the 315 MT's held all the power at 640RWHP? That sounds like it should be enough for me then as well..
As you go up in power, traction becomes a huge issue. You have to learn to modulate your right foot input
What tires are you switching to?
Just want to make sure I make the right choice.
Glad to hear you guys saying that the 345s and flares/tub isn't necessary. I can put that $4k into something else if I can hook.
Dont go with the ccw but rather another z06 style 18x12 in the rear. Grab some 345/30/18 or so and some fender flare's. Could do it for under $2500 and be more than happy. Im the same as you my wheels that are on the car stay on the car no matter where I drive it
