Dont go with the ccw but rather another z06 style 18x12 in the rear. Grab some 345/30/18 or so and some fender flare's. Could do it for under $2500 and be more than happy. Im the same as you my wheels that are on the car stay on the car no matter where I drive it
Well the only problem I have with that is finding wheels that are the same weight as the factory z06 rims. I could get some aftermarket rims but it seems the only ones that are the same weight/lighter are going to cost me $3k + .
I was very particular about finding OEM Z06 wheels for my FRC because the repro C5Z06 rims were heavier.
I bought my ccws on here for 1200, m&h 600, new bfg fronts 600...deffinitely could have done without the bfgs.
and to milan...please explain how the 345 won't out hook a 305? my posts are in reference to street driving.not track where prep is layed
What are the drag radial options for 345's? A 345 street tire isn't going to out hook a 305 DR
theres 3 good options IMO , Mt's is 27.5" tall, m&h is 28", amd bfg is 26"...there is however a set floating in the c5 fs section for right around 400 and theyre brand new...I chose m&h however for their height for my turbo car
and if I have someone creeping on my car at the track anyway because I went slower they can set me out our kick me...my car doesn't need prep to work from the dig.
lowers my gear ratio so I can be in boost longer per gear, at the track you'd want a 26" if you run the stock 3.42
Another question on this.. Would this help acceleration from a roll and stop? Or only at the track? I understand the lower gear means you can go faster MPH through any given gear so your top speed is higher, but wouldn't you be going slower through those gears than if you had 3.73 or 4.10's for example?
Still trying to understand.
in theory it slows acceleration but pulls more in the top end area...you would be in gear longer...example.when I was cam only my 17's with hoosiers(26") went 125mph in the 1/4 mile at 6400rpm...I switched to a 16" with 315/45's (27.2") I did the same mph but at 4200 rpm....in the street I could run a longer distance.now an fi application its not nearly as detrimental...boost pulls way harder than n/a...hence why you see people run low gears.3.42 is common for stick cars but an auto might drop back to a 3.15...low gear can help decrease wheel spin but mph's like a S.O.B....depends what it is you want, I'm not trying to be the fastest guy at the track, thats what ecs is here for.I have alot of friends with big single supras so I have to be able to pull the big end (if you've ever seen the texas mile street videos) I want to do 200 mph and thats just not gonna happen on a 26" tire and stock size gearing.it'd go into 6th gear and blow up most likely
Okay good info! Thanks for all the answers I definitely have a good idea of what to do. At least I know that I can save money and don't necessarily need the 345's. I can put that into some other parts, just not sure what.
I'm thinking of going w/ a fast 102 and 90mm tb (unless they make bigger) , but from what I was told those aren't very cost effective for FI applications because I won't see a huge gain for the price. Just looking at the the way my system is set up it visually looks restrictive from the MAF to the intake manifold.
just do the gto 90/90 way cheaper and people run 8's on them,but I would deffinitely start preparing to replace/rebuild the rear....passenger axle sucks
What should I watch out for besides the left output shaft? Remember I will not be taking this to the strip or launching on the street really. I tried to do a search on this before but didn't find a whole lot of info that pertained to my specific needs.
Everything in the drivetrain is at risk. People run 500+ hp with stock drivetrains but they all eventually fail. You need a built transmission, hardened output shafts and maybe a beefed up diff.
dont forget main shaft...95% of the time those go they take the rear out too, I just got lucky
A street car without hard dragstrip launches? Stock will probably be fine. I beat mine every way I could think of. When the clutch failed, I had a trans brace and hardened driver side output shaft put in while it was apart. Still beatin' it on the street... burnouts, power shifts with Nitto drag radials, bad wheel hop on occasion, and still 6 years without breakage, other than that one clutch.
Yeah I will not be on the strip and no hard launches. I think if I have to go back there I will change everything, but not sure if I want to replace it all unless I need to. Probably cost $2k or more plus labor to replace all that right?
