quick question,
Old May 9, 2011 | 07:19 PM
C5sleeper's Avatar
C5sleeper
Default quick question,
Can I still drive the car after a pulley swap from 3.8 to 3.6.. Belt will fit but I have to drive all highway miles from maine to ecs in Jerseynext week.
As long as I don't floor it and hit max boost I should be ok right? Going down to get a tune and a pcm update, or should it be done there?
Old May 9, 2011 | 07:26 PM
Gitusum's Avatar
Gitusum
yep should be fine
Old May 9, 2011 | 07:49 PM
corvette8189's Avatar
corvette8189
Old May 9, 2011 | 08:36 PM
AZZ-KIKR's Avatar
AZZ-KIKR
^^ yep.. I would just stay out of boost during that time if it were myself.
Old May 9, 2011 | 09:03 PM
C5sleeper's Avatar
C5sleeper
This is gunna be the worst 8 hrs of my life!
Old May 9, 2011 | 10:29 PM
AZZ-KIKR's Avatar
AZZ-KIKR
It will be worth it though!
Old May 9, 2011 | 10:42 PM
Milan's Avatar
Milan
If your car is tuned using speed density you can boost it no problem as long as you stay under whatever RPM you hit max boost at on your old pulley.
Example: Old pulley built 8 psi at redline, new one builds 8 psi at 5500 rpm. Stay under 5,000 RPM and you will be fine
Old May 9, 2011 | 11:24 PM
C5sleeper's Avatar
C5sleeper
its a maf tune for 8psi. so as long as i stay under that i should be good right?
Old May 9, 2011 | 11:31 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Agree with everyone - just chill and let ECS do the WOT part
Thanks,Matt
Old May 9, 2011 | 11:33 PM
C5sleeper's Avatar
C5sleeper
Thanks Guys, Appreciate it
Old May 9, 2011 | 11:47 PM
1redz06's Avatar
1redz06
You will be just fine, I have to drive two hours on my old n/a tune and injecters with an a&a supercharger to the tuner.
Old May 10, 2011 | 12:47 AM
4DRUSH's Avatar
4DRUSH
Just let ECS change the pulley, check the belt, etc. It's not worth trying to save a few dollars doing it yourself, especially if a problem arises.
To quick question,
