Intercooler
Old May 16, 2011 | 05:45 PM
reactor2's Avatar
reactor2
Default Intercooler
I currently have the procharger dual intercooler setup but I'm not a big fan of all the piping. I like the a&a and ecs designs (single intercooler) but I don't like the price. What are my options? Are there any decent and more reasonably prices single coolers out there? Im going to be running just 5-7 psi.
Old May 16, 2011 | 05:54 PM
95redz's Avatar
95redz
Could always luck out and find someone who is upgrading from the old-style A&A single to the new one. From time to time you see the kits surface on these boards.
For 5-7psi though, I don't think you'll have to many issues with the twins. If it was 15 - 17psi you were after, then I'd say you'd have a larger concern.
Old May 16, 2011 | 06:00 PM
reactor2's Avatar
reactor2
I wasn't so much concerned with the ability of the twin intercoolers handling the boost so much as I really dislike all of the piping. The dual setup seems like a gimmick to me as all the big boys run singles. Since I don't plan on running big boost do you know of any decent budget intercoolers?
Old May 16, 2011 | 06:02 PM
racerrob333's Avatar
racerrob333
Im going to a air to water intercooler. My old one is a eastcoast one the biggest one they got I could sell it for a good price
Old May 16, 2011 | 06:17 PM
reactor2's Avatar
reactor2
Pm sent.
Anybody else upgrading? Ideally I'd like piping as well, I already have the a&a sheetmetal radiator piece as well as the a&a aluminum polished upper elbo.
Old May 16, 2011 | 06:37 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
You won't need some of the pieces, like the BOV. I can take some money off for those things.
http://www.aacorvette.com/performanc...products_id=87
Old May 16, 2011 | 06:41 PM
Blow Torch's Avatar
Blow Torch
I actually prefer the dual setup. It does a good job cooling the charge, makes GREAT power, and with the coolers on the side, the engine runs super cool and NEVER overheats
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Pm sent.
The only downside to that is that the A&A ducting is smaller then the ECS ducting, so you will be bottle necking your ducting from the intercooler assuming you buy RacerRobs. I guess for 5-6 lbs it probably will not make much of a difference though. Feel free to give us a call if you need any of the adjacent parts to the intercooler, good luck with it.
Old May 16, 2011 | 07:36 PM
avenger88's Avatar
avenger88
im actually in the same boat dude, going back and fourth weather to get a fmic or stick with my twins..my cars currently at 706 rwhp at 11lbs. im uping the boost, a few real good shops say its not guna be a restriction then others do. also bob from epp actually likes the split set up. He kept it on a road race z06 for more air flow to the radiator and that car was over 760rwhp on a mustang dyno and had no prob with ait's. . also meth helps
Old May 16, 2011 | 09:10 PM
racerrob333
Pm sent.
pm answered my piping would not work for u Im running a super victor intake but for the intercooler 700 dollars maybe has about 20 passes on it
Old May 16, 2011 | 09:14 PM
racerrob333
I had the twins to start with but when I put more boost I needed the bigger intercooler to keep the intake temps down. Now that Ive went to the f2 need to go air to water cause this intercooler will never be enough
Old May 16, 2011 | 09:45 PM
avenger88's Avatar
avenger88
how many pounds of boost did you find it to start being a restriction? also what head unit did you have and were you running meth? . . .f2 is a bad ***** funka must be a sick ride. . . mines a forged 347 d1 and my dads is an iron block 408 f1r at 26 lbs of boost, scary scary street car
Old May 17, 2011 | 07:17 AM
racerrob333
We were running a 427 with a f1r @ 26 lbs by the end of the run the temps were at about 190. On the street it was fine the intercooler could do its job.
Old May 17, 2011 | 04:04 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I based my purchase on personel research. You should do alot of
research and OUR opinion's won't count.
A well made and a intercooler that has gone thru alot of R&D
is important to me. Frankly you will have alot of late nights
decideing what is right for you.
Good luck and let us know what you chose and why.
Old May 18, 2011 | 12:17 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Explain to me why, if we run 3" piping from the blower to the intercooler, 3 1/2" tubing from the intercooler to the throttle body would become a "bottleneck".
The 3" tubing carries heated (and therefore expanded) air to the intercooler. The air coming out of the intercooler is cooler (and therefore denser) which would actually allow more air to flow through the same size tube. While the difference would be minimal, it still favors airflow on the back side of the intercooler.
Only if you ran 3 1/2" into the intercooler and 3" out, would the ducting to the throttle body be a restriction.
I know you think I must be wrong, so explain it to me.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old May 18, 2011 | 02:02 AM
corvette8189's Avatar
corvette8189
Old May 18, 2011 | 10:21 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
With the boost you are running I would not worry about changing unless you want to up it to 10lbs or more, just install some spal fans behind them for a cooler charge, I got a set
To Intercooler
Old May 19, 2011 | 03:14 AM
MyEBc5Z's Avatar
MyEBc5Z
Daaaaaaaang Andy went all "bill-ny the science guy on yo ***!"
Old May 23, 2011 | 07:50 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
The only real proof would be to measure the pressure at the intercooler exit and then the throttle body entrance. Then reverse the gauges and measure again. I'll bet there isn't any negligible difference. Either way, I made over 1000RWHP with that bottle neck.
Old Jun 2, 2011 | 07:45 PM
reactor2's Avatar
reactor2
Just a follow up. I've decided to ditch my twin intercooler setup in favor of the A&A single itercooler setup. As an engineer I appreciate simple, effective, and elegant designs. Oddly enough I judge a solution based on the gag factor. The twin procharger twin intercooler setup is simple less effective with A LOT more overhead than the A&A setup, and quite simply all that tubing makes me gag as it is unnecessary for my goals.
