reduce engine power Help !!!
Old May 29, 2011 | 04:11 PM
venomws7's Avatar
venomws7
Default reduce engine power Help !!!
O.K guys I tried to take the car to the dyno yesterday but when I started the car I got the reduce engine power thing...
The weird thing is that as soon the engine light comes on the fuel/oil/temp gauges goes to zero and the car almost dies my tuner still didnt check the car But any heads up will be appeciated...
Also any dyno numbers guess pump gas 13-14psi for now. !!!
Thanks in advance.
Sam.
Old May 29, 2011 | 04:27 PM
bullitt4110's Avatar
bullitt4110
Did you pull the codes?
Old May 29, 2011 | 07:20 PM
corvette8189's Avatar
corvette8189
short answer- delete all codes and see if it does it again
Old May 29, 2011 | 08:46 PM
edcmat-l1's Avatar
edcmat-l1
What's the setup? If it's FI (sounds like it is) it's probably all in the tune.
Old May 29, 2011 | 09:50 PM
Milan's Avatar
Milan
P1514 table in HPtuners...multiply it be 2 and see if it still does it
Old May 30, 2011 | 12:44 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If it's happening from simply starting your car, you're most likely out of bounds on your P0121 table. Raise the max and lower the min values. Set the max at 85kPa and min at 35kPa. Go to Engine Diag>General> TPS sensor.
You could also be out of bounds on the P0106 table, located in Engine Diag> Airflow> MAP sensor. Raise the max and lower the min in those tables too.
Old May 30, 2011 | 11:54 AM
a/c man's Avatar
a/c man
mine did that once it was a loose ground wire on the back of the motor
Old May 31, 2011 | 05:14 PM
venomws7's Avatar
venomws7
Thanks guys...
Bret thanks man I'll try that tomorrow...
Old Nov 27, 2011 | 10:26 PM
MotoJB's Avatar
MotoJB
What ever did you find out? I had a similar issue tonight...
Old Nov 28, 2011 | 12:25 AM
BLOWNBLUEZ06
I replied to your post in Tech. You might need to raise the airflow values in the 1514 table by 10% or so, but your elevated idle makes me think that it's a vacuum leak.
Old Nov 28, 2011 | 12:31 AM
MotoJB's Avatar
MotoJB
Thanks bud...appreciate the help. Will check into it.
Old Nov 28, 2011 | 12:07 PM
user_name's Avatar
user_name
You still end up scaling the VE and IFR tables in my experience.
To reduce engine power Help !!!
