Octane Boosting
Old Jun 7, 2011 | 07:29 PM
ESBESQ's Avatar
ESBESQ
Default Octane Boosting
Was looking for a reasonable way to boost octane and came across this article:
http://www.bobistheoilguy.com/forums...&Number=626470
I checked around and Toluene is selling for just under $15/gal. Tell me what you guys think.
And as for my fuel mileage problem - it's still there even after Andy adjusted the tune. Dealer couldn't find anything wrong with any sensors either, so I'll be taking it back to Andy this week.
Old Jun 7, 2011 | 09:43 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
I did the math on this as well as xylene and it is half as costly to buy a good octane booster.
Look at Klotz - it can be had for around the $55 per/gal (shipping included) and will treat approximately 4 tankfuls.
Old Jun 7, 2011 | 09:52 PM
ESBESQ's Avatar
ESBESQ
I'll check it out.
Anyone know about this stuff:
http://www.dynotabdirect.com/
I also saw something in the Summit Racing catalog that you install in-line and/or drop into your tank and it supposedly boosts octane to some ridiculous level, anyone know about that?
Old Jun 7, 2011 | 11:20 PM
Z06supercharged's Avatar
Z06supercharged
Klotz is excellent. I use it all the time. I mix 1 to 1.5 oz/per gasoline gallon depending on how warm it is outside.
I buy 1 gallon cans of it for like $54 shipped.
Old Jun 7, 2011 | 11:36 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
What about looking at some TORCO too!
Thanks,Matt
Old Jun 8, 2011 | 10:20 AM
0C_Williams@RPM
Former Vendor
yeah, Matt...maybe you should look at some Torco...
...has a nice coating effect, don't you think
too!
Thanks,Matt
Old Jun 8, 2011 | 12:09 PM
madmatt9471
I just threw that out there since no one had mentioned it yet!
Interesting pictures!
Thanks,Matt
Old Jun 8, 2011 | 12:33 PM
ESBESQ's Avatar
ESBESQ
The product I saw in Summit is called Fitch:
http://www.fitchfuelcatalyst.com/products/reviews.cfm
Supposedly it bolts on and raises 91 octane to 93 (at least that's the implication) and comes with a 5 year/250K mile warranty. The corvette kit is about $250. Anyone have any experience with this product?
Old Jun 8, 2011 | 12:44 PM
Z06supercharged
Torco does leave that reddish color all over everything and even though it bothered me to see my afr sensor covered in it, it didnt seem to affect its readings. The stuff sure works tho. I tried Klotz and it seemed to work just as well with no reddish coatings everywhere so in my mind anyway I liked it better just because of that.
Old Jun 8, 2011 | 04:34 PM
0C_Williams@RPM
Former Vendor
Given enough time (and it's not that long) the reddish stuff becomes an issue.
I started using and Klotz and it was so good that I did the buy-in and became a dealer.
Old Jun 8, 2011 | 10:12 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Torco has been around a long time, and is a proven octane booster. I've seen the inside of my motor and heads over the years, and it's never looked anywhere near that bad. Any parts/motor failures that I've had over the years, have never been attributed to any build up of Torco, but from hard driving combined with previous mec errors...
There are those that think if you use more then the reccommended amount, it will work better. This may account for some of the pics above, the other reasons these pics were chosen are obvious...
Old Jun 9, 2011 | 03:27 PM
stevieturbo's Avatar
stevieturbo
Methanol is cheap. Just add it to the fuel 10-15%
Old Jun 9, 2011 | 03:29 PM
madmatt9471
I guess it seems that either one you use it should be good, at least if I decided to use either or on track days I would be fine -
It might come down to availability or buy Race Fuel at the track! Ouchy!
Too bad Sunoco wasn't around everyother corner!
Thanks,Matt
Old Jun 9, 2011 | 09:37 PM
hobbesnmina2001's Avatar
hobbesnmina2001
St. Jude Donor '10-'11-'12,'14
My ex-employer (refinery) use to make up the fuel for Bobby Unser since they sponsored him and a main ingredient for his race fuel was toluene.
Toluene has also been used as a blending agent for keeping methanol from dropping out when adding more the 10% methanol to gasoline.
Ethanol does not need a blending agent so it is not necessary when blending e85 or various % of it.
Toluene is also better then xylene in race motors as the rate of speed burn can be used with high winding formula cars. Xylene has a slightly higher octane (~2 points) but burns slower.
Carlos
Old Jun 9, 2011 | 10:40 PM
Milan's Avatar
Milan
It will lean you out though...
Also not enough BTUs...ethanol/E85 would be a much better solution
Old Jun 10, 2011 | 02:20 PM
stevieturbo
Obviously you re-tune to take advantage of it. Otherwise adding anything is pointless.
And 10% would have a very small effect on AFR's but be enough to add a safety margin from detonation
To Octane Boosting
