TNT Problems
Old Apr 24, 2002 | 01:25 AM
Jason 98 TA's Avatar
Jason 98 TA
Premium Supporting Vendor
Default TNT Problems
Hood doesnt shut with the solinoids mounted on the purple people eater & it whisles when the car is running, sounds like air is leaking between the t.b. & the Purple. Any ideas on what I can do?
Jason
Old Apr 24, 2002 | 11:29 AM
99 Corvette's Avatar
99 Corvette
Default Re: TNT Problems (Jason 98 TA)
When I put the purple ring on I put a board flat against the front and hit it with a hammer then kept pressure on it while I tightened it up. I don't know about the bracket problem, mine came with a bracket that mounted to the intake manifold :cheers:
Jerry
Old Apr 24, 2002 | 12:46 PM
intel55's Avatar
intel55
Yeah that lil alum. holed bracket may need an extension. When first had that bracket, the hood would not close so I had to go the hardware store and get some more alum. to make an extension. TNT then sent me the bracket that mounts to the intake manifold.
Old Apr 25, 2002 | 03:06 PM
JMon's Avatar
JMon
Cruise-In III Veteran
Default Re: TNT Problems (intel55)
I actually redid my bracket. The one that comes with TNT just isn't designed well enough.
Also My intake didn't have screws for it, so I had to tap it out. Actually when that purple piece wouldn't go on, I just took off the throttle body, put it on the floor, lubed it up with grease, put the purple part on, and stepped on it.
Then put the joined two back on. Throttle body comes off in about 5 min, so it's not worth your time to mess with hamering it on, as you might break somthing.
BTW once you get it installed, it is great. I have all the toys with it. NX bottle opener, window swith, TPS, NX switches, Nx purge, Nx heater, and the coolest part the hurst T handle with the activation button.
To TNT Problems
