* Injector SPECIAL *
Old Jun 23, 2011 | 04:22 PM
Jennifer @ TPE's Avatar
Jennifer @ TPE
St. Jude Donor '12
Default * Injector SPECIAL *
INJECTOR SPECIAL:
MORE THAN 10% OFF PLUS FREE SHIPPING
Siemens DEKA IV Mototron 80lb/hr High Impedance Injectors with EV1 or USCAR Connector
$389 shipped
anywhere in the lower 48 states
These retail for $439.99
These injectors flow 80 lbs/hr at 43.5 PSI ( 3 BAR ) and even more at greater PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector.
These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures.
Specifications:
  • Static Flow Rate: 80lb/hr = 875 cc/min
  • Dynamic Flow Rate : 18.6 mg/pulse 2.5ms PW, 20 ms Period
  • Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
  • Connector: Bosch EV1
  • Series: DEKA 4 ( DEKA IV )
  • O-Ring Type: Viton
Siemens DEKA IV Mototron 60lb/hr High Impedance Injectors (Long or Short Style) with EV1 or USCAR Connector
$359 shipped
These retail for $399.99
These injectors flow 60 lbs/hr at 43.5 PSI ( 3 BAR ) and up to 85 lbs/hr at 87 PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector.
Specifications:
  • Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
  • Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
  • Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
  • Gain: 0.11ms/mg
  • Offset: 0.055ms
  • Turn on time @ 14VDC: 1.14ms
  • Turn off time: 0.85ms @ 600KPa
  • Orifice Type: Multi-orifice
  • Spray Pattern: 30 Degree Spray Cone
  • Factory fitted with Viton upper and lower o-rings
ALL INJECTORS FLOW MATCHED WITHIN 1% FROM THE FACTORY
You can purchase these via paypal to Jeff@TotalPerformanceEngineering.com, or by calling me at the shop (702) 632-0270.
Old Jun 27, 2011 | 02:12 PM
Jennifer @ TPE
St. Jude Donor '12
I am currently packaging up all orders that came in over the weekend. You will have tracking numbers here shortly
Old Jun 28, 2011 | 01:42 AM
STEEL's Avatar
STEEL
I have a 383 procharger build with a RSI Stage 3 fuel kit and looking for 750hp with room to grow that is streetable. would the 80 injectors get me to my goal while being street worthy?
Old Jun 28, 2011 | 02:59 PM
Jennifer @ TPE
St. Jude Donor '12
Yes, without question the 80s are what you will need to go with and will definitely get you to the 750hp +
Old Jun 29, 2011 | 02:47 PM
Jennifer @ TPE
St. Jude Donor '12
ttt
Old Jul 4, 2011 | 01:47 AM
STEEL's Avatar
STEEL
ill take the 80's
Old Jul 4, 2011 | 04:26 PM
Jennifer @ TPE
St. Jude Donor '12
Sounds good.
We are closed for the day, but will open tomorrow. We can get them out to you tomorrow. Let me know how you would like to make payment.
ill take the 80's
Old Jul 5, 2011 | 05:08 PM
Jennifer @ TPE
St. Jude Donor '12
ttt
Old Jul 11, 2011 | 04:21 PM
Jennifer @ TPE
St. Jude Donor '12
This sale is good through the end of this week ONLY!!! Don't miss out!
Old Jul 12, 2011 | 06:10 PM
Jennifer @ TPE
St. Jude Donor '12
All orders have been packaged up and shipped out. If you placed on order within the last 2 days and have not received your tracking number please let me know. We have been having some issues with the tracking numbers being emailed directly from UPS.
To * Injector SPECIAL *
