p1sc help
Old Jul 8, 2011 | 11:11 PM
69ls6's Avatar
69ls6
Default p1sc help
have a 01 c5z wirh 51000.do not know for sure which cam is it [in car when i got it].tuner thinks its a ms3 for the way he had to tune it...tuner is very very good at what he does.I just got a smoking deal on a p1sc for ls1 corvette so I bought.comes with a 3.85 pulley and procherger said I needed a 4.00 to make 10 to 11lbs with is what I want.going to install a akly control kit and racetonix in tank pump wasn't going to do hotwire kit didn't think I needed it.the kit shows I need a 4 to 3 inch reducer for ls6 engine which is not in kit,do I need this for me to make 11lbs...have buddies making 650 with stock ls1 with blower cam vettes and I was hoping for at least 650 range if not more.car is not a dd,drive on saturdays may run races street or strip 3 or 4 runs a month.Alot of peaple tell me a good overlapping cam like g5x3 or my ms3 r good cams for this due to boost bleed offf and lowering compression a tad but still make great power..dont want this much boost or has people runs 10-12 lbs with blower cam and been ok..I know this pushing the limit of rods and bearings...needing some of these answered ,has anybody had one live with this boost on ls6.
Old Jul 9, 2011 | 07:34 PM
p1bz's Avatar
p1bz
Well, here goes. I believe you will need a 3.6-7 pulley for 10ish lbs. Do the hotwire with wire and a relay, use the factory gray wire that goes to the pump to turn on the relay, and you are done, price 10 bucks. 60lb injectors, good pump, and boosta pump. Leave the cam alone, it doesn't really matter, don't buy into the cam theory's. Put the blower on and boost it. 10-12 lbs is not a problem with meth. Without meth, probably not. Buy m/t drag radials, and clutch, and enjoy. Good Luck, Steve.
Old Jul 13, 2011 | 11:00 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
3.85 pulley on mine is 11psi
To p1sc help
