first thing is to check for trash blocking the raid. these cars are like vacume cleaners
Maybe try using straight distilled water instead of traditional coolant (might be worth trying the royal purple ice stuff since they just posted a video showing that by adding their stuff to the coolant system dropped temps. by a few degrees).
If those don't help, the next step would be to grab a dewitts/spal fan upgrade as it flows double the cfm over stock. TPE has these on sale for a great price...just picked up one myself.
If none of the above help, next would be to do a radiator upgrade followed by an electric water pump
what has changed? What have you done to the car or did it just start all of the sudden? make sure you have the air dam underneath your car, if its gone, replace it, fans turn off after 35 mph because they become ineffective.
Did it start running hotter after you removed the thermostat - ? Maybe the water is not staying in the radiator long enough to get cooled properly?
Also as suggested previously - be sure to check your air dam under car - if its gone then that will contribute to heat / not enough air flow directed etc. Happened to me long time ago - replaced air-dam problem solved.
FYI, 230 is not overheating. 240 isn't either. The 1st factory fan setting is programmed to come on at 235. I don't like those temps, but it's not overheating.
It usually runs much cooler. 180-190. My bet is dirty radiator. I was on a gravel road a while back and it was really dusty and dirty and getting to that there was a lot of cut grass on the road.
So what do you if it does not stay in the radiator long enough?
But what if it still climbs and then steams out?
The first three things to do is to clean the radiator externally. There is almost certainly trash blocking the air flow. If the car produces steam anywhere then it has overheated.
Then you have a problem for sure. If you have a car that runs one temp and it starts running higher temps, then it's worth investigating, but if you know everything is as it should be and running high temps, it's time to start buying some parts.
Glad ya got it figured out man. I figured it was the radiator bring clogged with debris. Had identical issues with my first vette. In my case, the car was running around 190-210 on average and then all of the sudden it would run at 210-225. Then a month later it would consistently be at 230-240 and the coolant would boil over. I (just like you) began asking around the forums just looking at the radiator in the car u couldn't tell it was clogged. so I pulled the radiator and held it up to the sun light and it was slammed full of grass, dirt and other debris. Once I cleaned it out with a garden hose it was all good and the car went back to running 190-210
