Help Ls6 supercharged issues!!?
Old Sep 8, 2011 | 10:54 PM
jobberone's Avatar
jobberone
jobberone
Start with the simple things first. Wires then plugs. Advanced can check your battery and alternator as well.
Old Sep 9, 2011 | 02:09 PM
HP_Addict's Avatar
HP_Addict
Most guys run teh NGK TR6 plugs with a supercharger. Stock wires will work fine, or you can splurge on the high $$ Taylor wires. I would recommend boots on teh plug wired to protect form teh heat. You can do a compression check while you are right there, but I don't think that would cause a miss.
Old Sep 9, 2011 | 03:22 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Originally Posted by nickk4469
I linked the code reader and it showed that no codes had been set.... I guess my next step will be to check the "boost a pump." Anyone else have some idea's, I'm going to check the battery as also was suggested. I wish I had a good performance shop in the area....
I would not trust that reading. If the check engine light came on a code was set. It may be a H (history) code now but it should still be visible.
Go to an auto part store and ask them to read your codes for you.
If this only happens in boost I'm betting on the BAP problem. Sounds like you are going lean. It also sounds like the results of a bad O2 sensor but I'm not sure if that only happens when you are into the throttle or not.
Either way, go easy on it until you get it figured out.
Good luck, safe driving.
Old Sep 9, 2011 | 04:53 PM
nickk4469's Avatar
nickk4469
I appreciate all the input guys! I'm good at turning a wrench but am still in the learning process of diagnosing my own problems when they occur. A couple more questions... when testing the boost a pump, will just applying pressure to simulate boost cause the volts to change or does the BAP work off rpm's along with boost?
Old Sep 9, 2011 | 06:14 PM
heavymetals's Avatar
heavymetals
It just works with boost.
Depending on how old the Magnavolt is.
Some have the air switch built in and some have the switch ext.
Monitor the output (grey wire) with a DVM and apply pressure.
Old Sep 9, 2011 | 07:36 PM
nickk4469's Avatar
nickk4469
I thought it had a magnavolt but I got to thinking again it and the original owner had said he had to replace it a few times. It now has a MSD BAP, it as an internal switch built in it. Do I check this the same way as the magnavolt?
Also I just ordered magnecor wires and Koolsox from Lingenfelter. So it will be a few days before I get to try out new wires and plugs.
ok,
Old Sep 9, 2011 | 07:43 PM
nickk4469's Avatar
nickk4469
Sorry if my grammar is off or some sentences don't make sense. I do most my writing on here from my phone. It tends to make it hard to review and impossible for me to edit what I have written.
Old Sep 9, 2011 | 10:35 PM
heavymetals
Yes. just monitor the output and activate the switch or trigger.
Old Sep 20, 2011 | 06:22 AM
nickk4469's Avatar
nickk4469
Default Found the issue, now what!?
I pulled the plugs and found the #6 cylinder electrode is broken off. It appears to be caused by heat maybe... What are my next steps? Is the plug tip still in there? Did i damage something, or did this break from detonation? The plugs that are in it are AC DELCO 41-110. The rest of the plugs looked really clean, almost to clean i think. The Grounding electrode is clean and almost a whitish Grey color on every plug except the broken one. I have no idea when these plugs were put in or how many miles were on them...
Old Sep 20, 2011 | 08:41 AM
helga203's Avatar
helga203
Change your plugs to NGK TR6 plugs and your good to go. Gap .028 to .031.
Old Sep 20, 2011 | 12:20 PM
nickk4469's Avatar
nickk4469
So i shouldn't worry about that little piece of the spark plug that is missing? It is the very end of it (the part you would normally bend to to gap the plug) that is broken. where would have it went other then sitting on top of my piston?
Old Sep 20, 2011 | 12:50 PM
02402ramair's Avatar
02402ramair
They normally burn off and are spit out the exhaust. Replace the plugs with a NGK TR6 or the safer NGK BR6EF non projected tip plug. Have the tune checked and fuel pressure at WOT checked for piece of mind.
Old Sep 20, 2011 | 01:10 PM
  #33
had2have-it's Avatar
had2have-it
There's are reason why it's torching the plugs. You said the previous owner had to replace part of the fueling system a couple of times...thats a red flag for me. Also the previous service may have stirred up some debris that's now affecting fuel filters or injectors.
Old Sep 20, 2011 | 08:47 PM
  #34
nickk4469's Avatar
nickk4469
The tuning shops i talked with today seemed concerned that I may have done some damage to that cylinder. Is this commen for the strap of a spark to fail on a boosted motor, I bought a set of TR6's and gapped them to around .33 +-.1. Should I just put the plugs in and try running it, or should I just skip to the expensive path and have the head removed and inspect for damage? As for the fuel system failing previously it was because the magna volt had failed from what I understood. The car had about 5k on it when the Maggie was installed and now has around 100k on it. The car was gone through and checked good for compression and leak test before I purchased it. It ran like a top until this happened..
Old Sep 21, 2011 | 08:33 AM
  #35
helga203's Avatar
helga203
More than likely you did not damage anything because you continued to drive the car and revved it to 6000rpm. You would of known it something was damgaed. Put the plugs in and injoy; you got lucky. The only thing you could do is check compression to see if the debrie bent a valve but i highly dout it. The piece of spark plug is long gone.
