Considering building a fresh and new 402 forged motor to take place of my blown LS1 with 50k on the clock. My goal is to ahieve 800 to the wheels either way but not sure if the LS1 is even interested in my ideas and is probably giving me the but it's not the thumb finger he's givin. Anyway, this current ls1 is capable of around 600 to the wheels with a few Minor changes but my foresight is looking at 800+ sorta levels to the wheels. Should I just get a pulley to make the numbers happen and hope for the best or should I build a anew motor to replace. I have seen several write-ups about the LS platform surviving past 1200hp in stock form so who knows. Also, what sorta boost changes am I looking at when going From an a&a 3.8 to say a 3.6 or 3.4. What do you all think?
Motor..
Stock ls1 bottom
Ls6 243 heads and intake
Custom cam 224/230 595lift with good springs
Arh headers
A&a supercharger kit
Good tune getting 565rwhp
Motor..
Stock ls1 bottom
Arh headers
What you are saying here is stupid yes may have done 800 rwhp but that is on the dyno. Will tell you that will not stay together very long at all.. Build you a ls2 motor with good parts to make it stay together for some time anyway.... Robert
I am in the same boat as you OP. I am making 600 now with my Novi and I am planning on a motor build over the winter to handle 900, but I'm looking for 800ish. I want bigger cubes but not excited to spend more money. I will most likely just rebuild my 346 will very good internals. Good luck with your quest, I'm going to watch this thread closely!
its your choice both will make 800. i went with the 346 and I'm over 900. so it can be done, but i wish i went with the 402 from the beginning but that's because i want more and more power.
if I went with a 402 block I suppose I could buy a shortblock that's ready to go? or would i need to buy block/crank/piston...etc...then have it machined and checked at a machine shop. What have you heard folks doing?
Check out Texas Speed. You can pick your options and have a ready to drop in motor delivered to you. There are other builders you can go with as well.
Nothings wrong with a 427 but its not as easy of an install. the 427 block and other parts are different than what I have. Right? someone correct me if I'm wrong on this.
Since you mentioned texas speed do you know anything about thier quality of work installing the A&A supercharger?
They seem to have a pretty good reputation. I installed my own A&A s/c. Mine works/looks good and they are alot more qualified than me so I wouldn't worry too much about it.
Incorrect, as long as the correct reluctor wheel is installed it's drop in and go, there are also electronic boxes that compensate for alternate reluctor wheel tooth setups.. (58x to 24x)
I put an LS7 block in my 2000 coupe with no issues (other than who built the motor) Truthfully I wouldn't suggest it based on the cost of an LS7 block vs LS2/LS3 block or even a 6.0 iron block.
So many options, everyone has an example of every block/stroke/bore combo making 900 rwhp, so where you take it is up to you and the shop you're working with.
It has never made good sence to me to pull apart a good running motor to rebuild with stronger parts.I would first sit down and work out the true costs of building or buying.I think you will find it's cheaper to sell your motor and buy one that is done.
Good luck.
Remember the fuel system.
If the block is the same that means I can use my old stuff?
-Heads
-headers
-A&A supercharger brackets and such
That's what i thought..........427 block maybe a similar form factor to that of an LS1/6 but my parts such as heads/headers/intake etc. would not be interchangeable and useless. That was my point i guess in the earlier post.
