Too much boost causing REP?
Old Sep 12, 2011 | 08:43 PM
Prop Job's Avatar
Prop Job
Default Too much boost causing REP?
When I rev above 6200ish and let off the throttle the car will go into reduced engine power and hold about 2500 rpm until I delete the codes. It doesn't do it every time but I'd say it's about a third of the time. In my mind what's happening is that when I let off the throttle it's telling the throttle body blade to close but the boost isn't letting it until it bleeds enough off so it's going into rep because the pedal and tb don't agree. I've got a big red race valve and it's as open as it'll go. I'm running an LS2 90mm throttle body. Anybody got any ideas?
Thanks,
Alex
Update: The code was p1515 (command vs actual throttle position error). We swapped throttle bodies and that fixed it.
Old Sep 12, 2011 | 10:22 PM
Z06wanted's Avatar
Z06wanted
I am sure it's something simple. Kris will be back off vacation next week and be able to check it out. Mine used to do it when LMR didn't scale injectors back and would max out grams per cylinder. I saw your tune and it's not that.
Old Sep 12, 2011 | 10:39 PM
Prop Job's Avatar
Prop Job
I wish I was going to be around so he could but I'm leaving before he gets back so I was hoping somebody on here had seen this before.
Old Sep 15, 2011 | 02:06 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Pull and post up the codes using the DIC and post them. Will be 1278, P0102,P0103 and then the problem. Usually P1516 or P1514, but could be P0106.
Old Sep 15, 2011 | 02:37 PM
Prop Job's Avatar
Prop Job
I had Kris turn the codes off hoping that would fix it so I'm only getting those first three, but I think I remember it being 1516.
Old Sep 15, 2011 | 04:32 PM
BLOWNBLUEZ06
Are you spinning the tires and pedaling the car when this is happening? Get those codes turned back on so we can get some hard data.
Old Sep 15, 2011 | 05:06 PM
Prop Job's Avatar
Prop Job
no tire spin. hopefully I'll have a chance to run it to Kris mon morning before it hit the road to get those codes turned back on.
I just got done doing some "troubleshooting" and it seems to be more dependent on what rpm it is when I roll into it. If I try the initial hit above 4k it seems to happen 100% of the time. that may not be the exact rpm but it's somewhere around there.
Old Sep 15, 2011 | 05:14 PM
BLOWNBLUEZ06
Are you trying to read the codes before resetting the PCM? You'll erase them if you do..
Old Sep 15, 2011 | 05:55 PM
Prop Job's Avatar
Prop Job
yea I read before resetting.
Old Sep 20, 2011 | 10:21 AM
02402ramair's Avatar
02402ramair
I returned from vacation and turned the ETC codes back on. I didn't want to turn them off but to satisfy Alex I did so anyway. No way to know whats causing problems if the codes are off. The car was throwing a P1515 code. Commanded and actual TP are not within calibrated range. I replaced the TB and problem went away. I think the car now has every bug worked out. Time to enjoy the car Alex!
Old Sep 20, 2011 | 10:22 AM
BLOWNBLUEZ06
Good work sir! Hope you enjoyed your vacation! (much neeed I'm sure).
To Too much boost causing REP?
