Window Switch
Old May 2, 2002 | 11:00 AM
Mystery Fan's Avatar
Mystery Fan
Default Window Switch
If you have a window switch set for 3200 to 5500, when it upshifts does the nitrous kick back on when the revs fall. I am concerned about having the nitrous on before the upshift is complete. Anyway to add a delay on the upshift?
Old May 2, 2002 | 12:15 PM
C5Noir's Avatar
C5Noir
Default Re: Window Switch (Mystery Fan)
If your RPMS are between that window at any time, the solenoids will be open. To make sure you don't spray through get the BPP TPS switch. That way if you hit the rev limiter the TB closes and shuts down the 'noids :).
Old May 2, 2002 | 12:22 PM
Mystery Fan
Default Re: Window Switch (C5Noir)
Who is BPP? Breathless? I have an A4 so I am not worried about hitting the rev limiter only having the nitrous on, while the tranny is shifting.
Old May 2, 2002 | 12:24 PM
C5Noir's Avatar
C5Noir
You won't have any problems then. The 'noids will be closed as you go through the gears :). However your RPMs must fall below 5500 when you hit hte next gear or no spray :(
Old May 4, 2002 | 12:22 AM
newberd's Avatar
newberd
Hey c5noir, read your tech file, good info, thanks. I have a NX GenX on the way, so I've doing the research thing before installing. Did I understand correctly, I don't need to worry about shutting down the noids during a shift with an A4? That means no need for the window switch. I have a stock tranny and don't plan any track runs. Just want a good time on the street. :smash:
To Window Switch
