Does this add up with????????
Old Oct 21, 2011 | 08:44 AM
helga203's Avatar
helga203
Default Does this add up with????????
I have a 99 vette ls1 stock engine 346 excpet for 42 injectors, kooks 1 7/8 headers, full ghl no cats exhaust,D1 procharger 3.4pulley. A&A dyno tuned 552 whp 12 psi boost. Now fully forged 9.5.1com, 6.0L block, LPE elderbrock racing alumin heads, 224,575 comp cam, 90mm TB, Fast 90mm intake same headers and exh. 80 injectors, D1- 3.1 pulley with IW 8" damper and flip drive. shop in chicago sub dyno tuned at 512 whp is this possible? They said thats all they could get out of it and said that was really good for the set up. Is this possible. I put over 8 grand into upgrades and got less hp???????
PS A&A 1000hp fuel system 93 pump gas no meth and they did a 3 bar SD tune. I will be picking the car up 2day so i would like to get info if possible to argue this if possible and their saying my BOV is causing it to surge now. It never surged before they said to put on a by pass valve????? Need help with ammo to justify them to do a better job or is this set up correct? Thanks guys
Old Oct 21, 2011 | 08:59 AM
robert miller's Avatar
robert miller
Something is wrong here on that tune are set up someplace. You for sure should have more rwhp than this.
Old Oct 21, 2011 | 10:37 AM
Darion's Avatar
Darion
Tell ya this, with what information you have there I would have a bunch of question too.
Hope ya get it all straight,
Darion
Old Oct 21, 2011 | 10:50 AM
robert miller
Darion
Should be in the 600 plus range also why did the guy do a 3 bar on this unless you where going over 18 lbs of boost should stay with a 2 bar. I dont think the shop does what he is doing on this set up man.... Robert
Old Oct 21, 2011 | 10:52 AM
ghost-1's Avatar
ghost-1
When I had my 383 with similar mods except I had a v-2 t-trim I made 654 at 9 psi so your numbers seem low. Who installed all the parts?
Old Oct 21, 2011 | 11:39 AM
robert miller
But even with a very safe tune on his car and no meth. These # of just 500 rwhp is crap for all this car has in it. Would like to see the dyno pulls and chart on it. There has be be a big boost lose are something here... I say above but if the guy is a tuner at all can look and see a drop are something here.....Robert
Old Oct 21, 2011 | 11:46 AM
Carlmc1's Avatar
Carlmc1
It sounds like they dont have a clue
Carl
Old Oct 21, 2011 | 11:47 AM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
With the right cam-in the 800rwhp range.
Waiting on the graph.
Old Oct 21, 2011 | 12:05 PM
corvetteracer22's Avatar
corvetteracer22
Thats def not right...
Old Oct 21, 2011 | 01:12 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
With everything you have mentioned...and especially because a problem developed that was not present prior to them having it & that they won't fix...I would take it to someone else. I also would say they deserve about $400 less cause their tune is complete crap if they even attempted one....anybody can do a sub-par tune & throw a car on a dyno...but it takes someone with education and experience to actually TUNE the your car. If you were a little off to where you think you should be is one thing BUT only if the car is behaving awesome and still making great power...Your car is doing neither or these things...you have a surging issue and are way below common sense numbers. Time to visit a new doctor cause the one "practicing" on your car is probably causing you more harm then good in the long run.
PS: Be warned though...Dyno numbers are sometimes used over the car's over all performance. Don't let big numbers fool you. Be smart and make sure your car is running perfect. If it is and your numbers look good you're all set. It is a balancing act. I wouldn't sacrifice the car's reliability just to get 20 more rwhp to show up on a dyno.
Old Oct 21, 2011 | 01:20 PM
robert miller
Need to see the pulls and graph.. Also tell him not going to pay him crap for a job like that on these parts, And him tell you that this is good # on that unit and parts. He really dont know what he is doing here.... Robert
Old Oct 21, 2011 | 01:30 PM
XtremeVette
Totally true!!! Don't pay him anything if you haven't already.
How you doing Robert? I still gotta go for a ride with ya sometime lol.
Old Oct 21, 2011 | 05:10 PM
helga203's Avatar
helga203
Thanks for all the replies guys. I'm on the go so i have a few seconds here. I'll have the graph later to nite after i talked to them i guess they made some changes 529whp 544trq with 3.1 pulley and 8"damper starting to slip at 5700rpm to 6700rpmwas down to 425hp and 325 trq and they resolved the surging i'll be back later thanks guys.
Old Oct 21, 2011 | 06:53 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
Could be a ton of things - slipping belt - clogged cats - three spark plugs disconnected - etc.. 5 anything with that setup is -way- under par. I made 505 rwhp on a Mustang dyno with a D-1SC, totally stock motor, using a 4.5'' pulley and a six rib belt.
Old Oct 21, 2011 | 07:59 PM
Blown_2001Z06's Avatar
Blown_2001Z06
This sounds similar to what I was building. With the pulley sizes you are overspinning that blower. With your pulley combo you are at ~68744 rpm impellar speed. Max recommended that I have seen is 62000rpm
Crank Pulley: 8.00"
Blower Pulley: 3.1"
D1sc Step Up: 4.1
Max RPM: 6500
8.00 x 6500 = 52000
52000 x 4.1 = 213200
213200 / 3.1 = 68774 rpm impeller speed
What BOV are you running? You could be bleeding off boost. This would also be a cause of compressor surge. You also should not be slipping the belt with the Flip drive. The belt slip can rob you of alot of power. Check all you vaccuum hoses. Any number of them can blow off at those boost levels.
Just for reference I was at 601rwhp on a mustang dyno at 5700rpm with a D1SC 3.85 pulley and stock crank pulley.
Wesley
Old Oct 21, 2011 | 09:04 PM
95wht6spd's Avatar
95wht6spd
clutch?
Old Oct 21, 2011 | 09:56 PM
Chrisrokc's Avatar
Chrisrokc
I would say it is the clutch if everything else looks perfect, but you are just down on numbers. If the end of the chart looks like it is falling off, it could be valve float?
I am trying to find my gremlin right now, I think I may have just found it. Intake gaskets. But my power band looks funky.. so I doubt thats the problem you are having.
To Does this add up with????????
Old Oct 21, 2011 | 10:52 PM
robert miller
Crank Pulley: 8.00"
Blower Pulley: 3.1"
D1sc Step Up: 4.1
Max RPM: 6500
8.00 x 6500 = 52000
Wesley
Good # with that pulley size on her.on a mustang dyno...
Old Oct 22, 2011 | 01:53 AM
a/c man's Avatar
a/c man
sounds like your bov is leaking boost! I had a close set up like yours and made 750rwhp with a auto somethings not right here brother!!
Old Oct 22, 2011 | 08:57 AM
helga203's Avatar
helga203
Default nit the beat pics
http://s1143.photobucket.com/albums/...0-22073949.jpg nit the best pic.
