Bottle
Old Oct 22, 2011 | 08:35 PM
elerico's Avatar
elerico
Default Bottle
can we put the bottle horizontaly in the middle compartement to close and hide everything ?
someone told me i need to put the bottle with the valve facing the front of the car
Old Oct 22, 2011 | 09:46 PM
tommie's Avatar
tommie
http://www.hotrod.com/howto/3447_che...trous_install/
Old Oct 22, 2011 | 10:07 PM
elerico's Avatar
elerico
not clear enough...
can I put the bottle in the hole..
http://members.***.net/mbrowning4/Nitrous/Bottle.JPG
or
http://www.turbomx5.com/images/trunk3.jpg
Old Oct 22, 2011 | 10:13 PM
tommie's Avatar
tommie
seen a few people mount them under the cover in the rear...
a 10lb bottle will fit with the cover
Old Oct 22, 2011 | 10:17 PM
elerico's Avatar
elerico
Ok I know everything fit
but, will i lost some pressure ?
or the valve need to face the front of the car
Old Oct 22, 2011 | 10:23 PM
tommie's Avatar
tommie
2.2 Bottle Orientation
Bottle placement is critical to the performance of your SNIPER™ nitrous system. It is important to understand how the bottle valve and siphon tube are assembled to properly orient the bottle in your vehicle and ensure that it picks up liquid nitrous while undergoing acceleration. All SNIPER™ nitrous bottles are assembled so that the bottom of the siphon tube is at the bottom of the bottle and opposite the bottle label (Figure 2).
Whenever the bottle is mounted in a lay-down position, the valve handle must be towards the front of the vehicle with the label facing up (Figure 3A).
If the bottle is mounted vertically, the label must face toward the front of the vehicle (Figure 3B). This orientation will position the siphon tube at the back of the bottle where the liquid N2O will be during acceleration.
If the bottle must be mounted parallel to the axles of the vehicle (sideways), the label must be angled at approximately 45° toward the front of the vehicle (Figure 3D). This orientation will position the siphon tube toward the rear of the bottle.
NOTE: When using a bottle with a siphon tube, the tall bracket should be at the valve end of the bottle and the short bracket at the bottom (Figure 3E).
The most efficient mounting is the lay-down position (Figure 3A) with the valve handle toward the front of the vehicle. This position allows the greatest amount of liquid to be used before the siphon tube begins to pick up gaseous nitrous oxide.
look at the instructions...
here are some for example...
http://www.holley.com/data/Products/.../199R10431.pdf
that is where i copied the text from... found the pic on the net... but all of the info is in the instructions above... or in the instructions that came with your kit
To Bottle
