Made the FI plung!!!
Old Oct 31, 2011 | 11:10 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default Made the FI plung!!!
After over a year of following the forum and listening to everyone's advise. I drove the car 900 miles to TPS to have Mikes shop install the A&A kit. It is a 98 with 95K miles. This link has the info:
http://forums.corvetteforum.com/c5-p...-new-post.html
The car is stock except for an exhaust. My question now is with headers and an intake being so expensive for a small gain. Why not wait untill the engine needs to be redone and replace with a forged stroker or bigger engine and run more boost, rather then spend so much money on headers and an intake. Obviously, you need to let the engine breath and the intake and headers will limit this, but I hear about people running 700RWHP with stock LS1 intake and exhaust.
Old Oct 31, 2011 | 11:48 PM
Robert 2000's Avatar
Robert 2000
Don't bother with an intake for FI.... However headers let it breathe and will make it more efficient you ll make more power on less boost (at least that's my understanding) someone else will chime in
Congrats and enjoy that new power and the power addiction you will now have
Old Nov 1, 2011 | 07:59 AM
Slowhawk's Avatar
0Slowhawk
Former Vendor
I usually recommend headers because the stock cats like to melt with the blower.
Old Nov 1, 2011 | 08:32 AM
RMS-MAN's Avatar
RMS-MAN
I'm the same way with my builds.
Old Nov 1, 2011 | 09:06 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Listen to the man!
Old Nov 1, 2011 | 11:02 AM
Darion's Avatar
Darion
So I have an A&A setup on my 04 LS1 through stock exhaust, just a catback swap for sound. I can't see doing an intake unless your looking for every last HP but I will change out the Headers this winter. Ya may want to consider swapping out the valve springs while they are doing the install with those miles.
I guess you could make 700rwhp through stock exhaust if ya wanted to run the boost and meth to do it, wouldn't be the most efficient way to go though. This winter I'll do a clutch swap and harden up the rear diff, figure just do headers while I'm at it. Header swap while doing the SC system install would be easy though since everything is out of the way.
Congrats on the new setup, your gonna love it!
Darion
Old Nov 1, 2011 | 11:11 AM
big454blockchevy's Avatar
big454blockchevy
My continually reading up on everything C5 in this forum, I've come to a conclusion , that the way to go with a c5 is FI. With this thread I have made up my mind . As soon as the 498 sells I will also take the plunge. Enjoy your newly acquired fix!
Old Nov 1, 2011 | 11:21 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default Let the Good times roll!!
Old Nov 1, 2011 | 10:15 PM
gottraction's Avatar
gottraction
As a recent convert myself, all I can say is there is no going back! After being a bit underwhelmed at the performance of a rented 505hp Viper , I knew that a supercharge Vette was the answer!
Old Nov 1, 2011 | 11:49 PM
robert miller's Avatar
robert miller
Old Nov 2, 2011 | 01:36 PM
kris6868's Avatar
kris6868
I have a stock LS1 with the A&A kit...
With only headers, catback an meth...
Im at 550rwhp
Reaching 700rwhp is alot of boost on stock internals...
Old Nov 2, 2011 | 09:43 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Stupid question-What happens if the Cats melt? and how would you know?
Old Nov 3, 2011 | 01:06 PM
DJJONESIVS's Avatar
DJJONESIVS
Massively down on power
Misfiring
Car will probably sound different
Old Nov 3, 2011 | 01:07 PM
DJJONESIVS's Avatar
DJJONESIVS
Misfiring
Low efficiency of sensor 2 on either bank
Old Nov 3, 2011 | 02:20 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Misfiring
If you were going to add headers would you go with or without cats?
Thank you,
Old Nov 3, 2011 | 06:58 PM
sami85L98's Avatar
sami85L98
Thank you,
If emission test required than go with Hi flow Cats or else catless and remove rear O2 sensor and let your tuner disable those O2 sensor, my preference would be AR headers or XSpower header system (which is copy of AR headers but lot less money).
Old Nov 3, 2011 | 08:19 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Hey a couple last things. Are we talking about any damage if the cats melt or is this something I should just do at some point. Also, do you make better power without the cats. I really appreciate all your help.
Thank you,
Mark G.
To Made the FI plung!!!
