Which Injectors
Nov 4, 2011 | 02:19 AM
Which Injectors
Got a 98, with a 112 maggie, cam, and all the bolt on's. Probably going to go with 60#, but which is a good trustworthy brand. I see the siemens all over, are they good?
Nov 4, 2011 | 09:37 AM
St. Jude Donor '11
I run FIC modded stock (LS2) injectors opened up to 60#. Been running them for years. Dig it.
Nov 4, 2011 | 09:53 AM
St. Jude Donor '08
Quote:
Originally Posted by
pinkey
Umm, that's what she said....
Sorry, you walked right into that one.
On topic: The SD 60's or 80's will suit you just fine.
Nov 4, 2011 | 11:37 AM
Nov 12, 2011 | 05:35 PM
Cruising
pinkey
I`m a fan of Injector Dynamics.
http://www.injectordynamics.com/ID1000.html This is quality-injectors
Nov 12, 2011 | 09:11 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Minimum 60 lb inj's, but a good set od 80 lb inj's will allow you room to expand
I run SEIMEN 80lb's in mine!
Thanks,Matt
Nov 13, 2011 | 12:25 AM
Siemens 83 is a great choice.
Nov 13, 2011 | 12:59 AM
Either the Siemen's 83's or Injector Dynamics 1000's. I'd go with the ID1000's.
Nov 13, 2011 | 01:11 AM
I run 9s with the 60 # Mototrons, FWIW.
Nov 13, 2011 | 08:52 PM
The 60's will be more than enough. The 112 is limited to 500-550rwhp.
Nov 13, 2011 | 08:58 PM
Slowhawk
Some of these suggestions are over-kill for a cammed LS1 witha maggie.
You could get away with 42lb injectors...but 60's give you more room for growth
Nov 14, 2011 | 12:30 AM
Nov 14, 2011 | 09:46 AM
ID1000's
Nov 14, 2011 | 10:19 AM
I've got the ID1000's and they're great, but totally unnecessary for this car.
Nov 14, 2011 | 10:44 AM
The 1000s are probably too big for his car. The 83s are probably not although they are overkill. They would allow him to grow. 60s are marginal at 700 HP although I'm not sure he can reach that goal with his current setup. So the 60s are fine as it is right now.
