I’m having issues keeping my IAT numbers down. At the drag strip my last run I saw IAT go from 100 to 172. I’m running an Alky control kit with 100% meth. I have 3 nozzles, a 3 prior to the super charger, a 15 at the outlet of my intercooler, and a 10 8” from that one. The IAT sensor was just replaced and it is about 14” away from the last nozzle. I logged meth pressure of a little over 100lbs for the entire run. Nothing is clogged (I checked). Meth is set to start at about 3 lbs and max flow is at about 10lbs of boost. I have the gain turned all the way up too.
Engine is a 427 with an A&A YSi kit putting out 20-21lbs of boost. I’m running the standard A&A intercooler.
Anyone with real world experience on how to get the IAT temps down. Should I go to a 50/50 mix with water? Is a bigger intercooler going to make notable improvements?
Not sure if I can help it breath much better, 90mm TB, LS7 manifold, Mast/ PI 275 series heads, AR 1 7/8 headers.
I really don't want to up the meth, I'm putting a lot in now and if it fails
It's just the way it works. I guess the other option is a bigger intercooler. Otherwise you just keep the timing out and take the power loss. Could be worse. It's not a KB...lol
Mike I would say something is out of wack. I am running same amount of boost and last pass in the quarter iats were below ambient. I have the latest a and a system also. A 15 and 10 nozzle for Meth.
YSI on full tilt does get pretty hot. Sounds pretty normal for a full quarter mile pull. Swap your last nozzle for a 15 and would help a little.
What intercooler? What was ambient temps?
I agree with the 15. What were ambient temps? Just how much meth are you using? You should be spraying a good bit. What % meth are you tuned for at WOT? How much fuel are you pulling? Is that temp after one run or are you hot lapping? I know you've looked but make sure the intercooler is clean.
Ambient was in the mid 70s. The tune is with 100% meth (lots of fuel is pulled from the VE table). With the 3, 10, and 15 nozzle that should be close to 18 GPH at 100psi.
The temps I saw were from a single run, just some idling in staging.
I'll take another look at the IAT sensor, I figured changing it with a new one would be good enough. I've heard several people drop below ambient running in the 1/4.
Something is not right. Check the sensor and get back to us. Yes you will suck down some meth just thought checking the reservoir visually would be a good check. You should have much lower IATs. Guessing either the sensor is wrong or you're not flowing as much meth as you think you should be.
You have your meth set up wrong. If your making 20 lbs, the meth should start spraying at around 6-8 lbs and have it spraying full at 18 lbs.
You'll need to adjust the settings in your pac controller. If your still on a 2 bar map that comes with the meth-upgrade to the 2.5 bar.
I set it up to come and to get max flow sooner in an attempt to ensure I had full flow early, hoping that would bring the temps down. Obviously that doesn't work
Who installed the methanol kit? I am concerned with the pump not getting a sufficient current supply, causing the voltage to drop. When I install the Alky kits, I run a "soak" test, running them wide open and at variousl levels of input pressures on the MAP to verify stable pressure. I do this for a few minutes to make sure it doesn't fall off for any reason. It just sounds like the meth kit may have a problem.
I installed the kit, I ran a power line from the terminal on the fuse box. I am logging pressure for the pump, got the sending unit form Juilo. The entire run I was right at 100psi indicated. I'm also logging voltage, 12.20 was about the average for the run.
Last year I logged about 135-140 lbs of pressure (didn't have the M3 nozzle installed) and my IAT went from 82 to 158 with about 12.6 voltage. That was with an old IAT sensor
had the same issue with my last setup. disconnect the 3rd nozzle and try it again. my issue was the 3rd nozzle was just too much for the pump even at 100lbs
