Eagle crank broke it two!!!
Old Nov 14, 2011 | 08:59 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
That is a bummer sorry to hear that!
What did EAGLE have to say about it?
Thanks,Matt
Old Nov 14, 2011 | 09:16 AM
mcantuaria23's Avatar
mcantuaria23
I have dragon slayer now after my eagle crank and rods broked.
Old Nov 14, 2011 | 09:23 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I trust the stock crank over Eagle products.
Old Nov 14, 2011 | 10:19 AM
jobberone's Avatar
jobberone
jobberone
Originally Posted by BLOWNBLUEZ06
No way I would weld on a 1100hp crank. Heat can change the characteristics. Especially that much heat. When you turn these cranks, you are cutting through the surface hardening. The nitride layer doesn't go far into the crank. .010 might be enough to get through that nitride layer.
This kind of thing is a small risk in a 4-500hp engine. IMO it's too risky in an engine making your kind of power. Over 800RWHP you should really consider a good forged crank. Eagle ain't that.
Old Nov 14, 2011 | 12:17 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Man that stinks, I did call it as the crank in your other thread!
Go with a better brand, once it's fixed you'll start forgetting about these issue's and enjoy your car.
Old Nov 14, 2011 | 12:36 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Originally Posted by a/c man
Car was running fine good oil pressure just a bad rattle at idle so I pulled the motor and found the crankshaft broken on #1 rod journal any one ever broke a eagle crank 402 ls2 the rods were std. and the mains were turned 0.10 well I need a new crank should i try the same or spend a little more for a compstar thank you in advance
FWIW Scotty, I wouldn't run any aftermarket crank after it's been turned down .10-that's goes for a Compstar, Eagle or K1.
Callies Magnum or a Lunati Sledgehammer maybe.
Old Nov 14, 2011 | 01:02 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Gotta say you are taking it like a champ! You've had more than your share of motor problems. Glad you're not getting down about it.
Old Nov 14, 2011 | 01:14 PM
golfinz's Avatar
golfinz
Dragonslayer
Old Nov 14, 2011 | 01:38 PM
jobberone's Avatar
jobberone
jobberone
Made a couple of calls and the consensus was the Eagle cranks are better than I gave them credit for. They say it appears the metal is still good going on drilling on them and racing experience FWIW. And they thought they were good to about 1500 flywheel. So my apologies to Eagle.
I think the crank either had an early crack in it already and/or it wasn't quite radius-ed properly causing the failure.
Between the Lunati and Callies crank they preferred the Callies saying the quality control was better again FWIW.
I'm sure many here either know this or have their own learned opinions but I thought I'd throw this out there.
Old Nov 14, 2011 | 01:44 PM
a/c man's Avatar
a/c man
help full info! thanks brother Im working with Eagle now to see what all they will do to help out
Old Nov 15, 2011 | 01:10 AM
silver408z's Avatar
silver408z
yea my thrust went bad last month and it was welded and turned 0.10 and now the crank is broken after 200 miles could be from all the stress?? thanks for the info about yours! was your block ok mine looks ok the bearings are good too just a broken crank
My block was fine but I did have the engine taken out and sent back to the machine shop. They went through the whole thing and rechecked everything. I use HKE to do the work. I had to wait like 3 months to get a new crank. HKE was having trouble getting cranks at the time due to that he no longer uses eagle and only callies, or so I was Erik. My rotating assembly is now Diamond pistons, eagle rods and callies crank.
We seem to have had similar issues. Short run down on my history and issues since my ls6 broke. This was all brand new parts, no cheap parts or used stuff.
Initial 408 went bad due to a intake valve seat falling out of a head from a top of the line manufacturer and ruined the engine. After lots of arguing, fighting and paperwork not sure I can say the name on a public. I replaced the heads, one rod and one piston. There was no cylinder scaring so I took a risk and hoped everything else was good.
After replacing this stuff and driving it for a bit, it developed fluctuating oil preasure issues. Got it apart and it had spun a rod bearing. The journal the rod was on had a small crack in it. HKE said it was fixable so they did the same thing you are talking about and had it welded and turned.
After that was fixed I got a bad thrust issue and a damaged crank again. The shop I use for the install and HKE both believed it was due to the under drive pulley going bad. I am finally running for almost a year and it all seems good.
Old Nov 15, 2011 | 10:46 AM
jmoody66's Avatar
jmoody66
Default sorry to hear
I hate to hear of this. Seems like your enduring the frustration I endured. I hope it works itself out for you.
I'm stress free now so I just watch the forum and see my history! Lol
