Car was running fine good oil pressure just a bad rattle at idle so I pulled the motor and found the crankshaft broken on #1 rod journal any one ever broke a eagle crank 402 ls2 the rods were std. and the mains were turned 0.10 well I need a new crank should i try the same or spend a little more for a compstar thank you in advance
Can't say that I've heard of one. How long have you had it? Sorry for the bad luck?
I had an eagle crank crack where a rod clamps on but I am pretty sure mine was damaged from a thrust went bad and the thrust went bad to the crank pulley coming apart
yea my thrust went bad last month and it was welded and turned 0.10 and now the crank is broken after 200 miles could be from all the stress?? thanks for the info about yours! was your block ok mine looks ok the bearings are good too just a broken crank
No way I would weld on a 1100hp crank. Heat can change the characteristics. Especially that much heat. When you turn these cranks, you are cutting through the surface hardening. The nitride layer doesn't go far into the crank. .010 might be enough to get through that nitride layer.
