The e85 thread
Old Dec 23, 2011 | 05:26 PM
  #61
B Neat's Avatar
B Neat
My guess is that it would lean it out, but thats just a guess. I wouldn't do it.
Old Dec 23, 2011 | 09:53 PM
  #62
Milan's Avatar
Milan
Originally Posted by helga203
Is it possible to mix in a gal or two of E85 at fill up with pump gas 93 oct just for safety if running high boost without meth. My car is running 18psi of boost on 93oct no meth so if i add E85 at fill up without any tuning changes will this give me any more protection when in high boost compared to adding a can of torco??????
Yeah probably couldn't hurt to add a few gallons.
Old Dec 23, 2011 | 10:04 PM
  #63
bullitt4110's Avatar
bullitt4110
It will lean it out some adding E85, how much or if its safe I am not sure.
Old Dec 23, 2011 | 10:53 PM
  #64
Z06supercharged's Avatar
Z06supercharged
Whatever stoich fuel you are tuned for then approx each additional 10% of ethanol over that will be about .6 leaner and 1.5-2 more points octane.
For example if you were set at 14.13 stoich for E10 93 octane your wot would be .6 leaner and your octane would be at 95 with E23 using a 5 to 1 blend of 93/e85.
5 to 2 ratio would yield you E301 and 96.4 octane but at E30 you will be running too lean especially wot without tuning changes and probably running out of injector as well top end.
Use the E85 blending calculator link here to take the guess work out of mixing for octanes and ethanol %. Use the bottom one on the page. http://www.intercepteft.com/calc.html#
Old Jan 6, 2012 | 01:32 PM
  #65
Z06supercharged
So I have been regularly testing the E85 % here at one station. The last 2 weeks I have been exactly at 92%. They get 1-2 deliveries a week so its pretty stable at 92% which is BS. I dont want 92%, I want 85% or a little lower. I know 92% is the legal max for E85 but geezus talk about wanting to make the most profit they can.
Old Jan 6, 2012 | 01:58 PM
  #66
dascorcha21's Avatar
dascorcha21
you are aware that the higher the ethanol level the better right? only downside is the fuel demand becomes greater...
Old Jan 6, 2012 | 07:08 PM
  #67
Z06supercharged
I dont mind higher or lower levels as I can run on E100 and anything in between just by changing tune which is no big deal but I wish they would be a little closer high/low % with their deliveries rather than me having to check it each fill up to see what the hell they delivered % wise.
Screw this min 72% max 92% bs wherever they decide they want it %. Thats ridiculous unless you have a flex fuel sensor on the vehicle to keep up with a 20% variance and even the flex fuel sensors dont go above 85%. Im looking into a dual chip PCM and I can flip on the fly between 2 different tunes with no laptop needed.
Old Jan 7, 2012 | 02:02 AM
  #68
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Originally Posted by mdaniel
You can keep your pro stock fuel system. I'll add a can of Torco for $10 and call it a day.
While I've run Torco for quite some time now, and plan to continue to do so at this moment, I have to look at the upside of E85. For me, I might just add some injector, a MSD 2351 Fuel Pump Voltage Booster to my Magnafuel pump, and have 2 tunes... I'd just switch on the Booster when I added the E85. This would give me both options.
Old Jan 31, 2012 | 12:06 PM
  #69
02402ramair's Avatar
02402ramair
I have several questions on E85. I am building a solid roller ls3 418 11.0 to 1 F1R auto FRC. I am looking at ID2000 injectors, Aeromotive pro series external fuel pump, stock pump Yed into -10 feed and -8 return.
Is this enough fuel system to make 1100 to 1200 rw on E85?
What stoich are the high HP guys running on E85?
What commanded PE AFR are the high hp guys targeting on E85?
Is the 105 octane enough to support 20psi at 11.0 compression?
Thanks for any info.
Kris
Old Jan 31, 2012 | 04:33 PM
  #70
dascorcha21
Kris
excellent questions
i am building a somewhats similar setup
418ci, novi 2500, ls7 heads with 11.1cr
shooting for over 1000hp through a TH400
im using a Intank 400lph Walbro fuel pump and External Magnafuel 4303 fuel pump -10 feed -8 return.
brett will be tuning my beast
Old Feb 1, 2012 | 11:07 PM
  #71
jose08m5's Avatar
jose08m5
what fuel pump and injectors would you guys recommend for a 650whp set up?
Old Feb 1, 2012 | 11:09 PM
  #72
jose08m5's Avatar
jose08m5
will this fuel pump be sufficient? Aeromotive 340lph
Old Feb 3, 2012 | 03:31 PM
  #73
02402ramair
Not sure as to I am just getting into the E85 but I would say ID1000's. 80's might do the trick but you would not have much room to grow. JMO
Old Feb 3, 2012 | 09:27 PM
  #74
99FRC Newb's Avatar
99FRC Newb
Originally Posted by CancerJCC
Thought I'd re-look into E85 after seeing this thread. No go for me though since E85 is only 2 cents cheaper than 93! This is on Ft. Benning, GA BTW and is the only spot around to fill up. Maybe in time though. (Oh I DD my V so mileage is a small concern).
i would compare it to 105 octane instead of 93 you'll be much happier with the price difference
Old Feb 5, 2012 | 10:58 AM
  #75
02402ramair
At close to $10.00 a gallon the E85 seems to be the way to go. It is costing me a $$$$$$$ to build the fuel system to support E85 but it should be worth it in the long run.
Old Feb 5, 2012 | 11:06 AM
  #76
JMBLOWNWS6's Avatar
JMBLOWNWS6
Im just torn right now how to mod my RSI kit. Pretty striaght fwd but I am debating on twin Deatsch 320 or Aeromotive 340's.
Old Feb 5, 2012 | 11:36 AM
  #77
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I went with Deatschewerks pumps because I have heard and seen great things from them. Also, they have a 3-year, no questions asked warranty. Can't beat that.
To The e85 thread
Old Feb 5, 2012 | 12:09 PM
  #78
JMBLOWNWS6's Avatar
JMBLOWNWS6
How much RWHP do you think they will support with a hotwire kit and no BAP. Im only making 900 with a 3.250 but have a 2.8 waiting in my tool box. Im like the others my ms109 race gas mix is too expensive and e85 is local to me And I refuse to make big numbers on regular 93 because Im a chicken
Old Feb 5, 2012 | 12:28 PM
  #79
Corvette-Chris
St. Jude Donor '08
They (twin pumps) have made just below 1,100rwhp on E85 on a turbo C5.
http://ls1tech.com/forums/fueling-in...301-pumps.html
Old Feb 5, 2012 | 12:45 PM
  #80
JMBLOWNWS6's Avatar
JMBLOWNWS6
Thanks Chris. Looks like Ill order those tomorrow.
