A&A install question?
Old Dec 13, 2011 | 09:56 PM
tech2262's Avatar
tech2262
Default A&A install question?
Hey installing my a&a kit 6rib v3 it's coming along good got the charger in. But I think I need more room for the intake pipe over the radiator did a quick mock up and doesn't look like it will make a connection. It trimmed the fan assembly and removed that top lip of the radiator do I need to also remove the first row of fins also?
Old Dec 13, 2011 | 10:34 PM
corvette8189's Avatar
corvette8189
did u lower the raidatior support bar, with the spacers
Old Dec 13, 2011 | 11:23 PM
a/c man's Avatar
a/c man
yea the spacers should get it! if not add more spacers washers as needed
Old Dec 14, 2011 | 12:22 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It takes some finesse to install the intake pipe, but it fits.
Old Dec 14, 2011 | 12:28 AM
a/c man's Avatar
a/c man
HES RIGHT MINE HAS A SLIGHT DENT IN THE BOTTOM TO HELP FOR CLEARANCE WORK IT SOME
Old Dec 14, 2011 | 10:04 AM
East Tx Muscle Cars's Avatar
0East Tx Muscle Cars
Former Vendor
it will fi t it just takes some Work. do NOT modify the radiator more than bending the upper part down a little. you dont need to cut off any rows that will only lea to a mess. the tube is kindof hard to get in there but it will fit fine.
Make sure you installed the spacers as stated above! thats what helps the kit fit the car perfect. If you running the stock radiator you will not need more shims than what come in the kit.
Old Dec 14, 2011 | 10:41 AM
tech2262's Avatar
tech2262
Yea I installed the spacers I followed all the steps you know what happen the right side radiator popped up out of the mount I am gonna try after work
Old Dec 14, 2011 | 06:37 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
Make sure the radiator is pushed down all the way, and pushed all the way back towards the blower/motor.
If you still can't get it to fit give us a call. 805-278-4107
__________________
Thanks, Josh Dodson
Sales Manager at A&A Corvette
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
Facebook.com/AACorvette
Old Dec 14, 2011 | 09:40 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Another trick is just to leave the lower rad supports bolt's loose-don't worry the rad support won't go anywhere if the rad hoses are connected.
You can push down enough to get the dongle on-then bolt the rad support back on.
One thing I always do it trim/grind the lip of the rad where the dongle touches-every little bit counts!
Old Dec 14, 2011 | 11:43 PM
bullitt4110's Avatar
bullitt4110
those are some good tips, I do the same.
Old Dec 17, 2011 | 08:57 AM
tech2262's Avatar
tech2262
I know my question sounded stupid and i know u cant grind into were the core channels are just never actually had to grind a radiator before.Yea thanks guys I got that top lip nicely with a carbide burr and a cut off wheel. Arun@ccP that sounds like the most affective tip. I will keeP u guys posted close to finishing up.
Old Dec 17, 2011 | 12:48 PM
a/c man's Avatar
a/c man
No questions are ever stupid! its when you don't ask that its stupid ;-) keep us posted
Old Dec 21, 2011 | 12:09 PM
tech2262's Avatar
tech2262
What did you guys do with the ps cooler it interferes with the down tube off of the supercharger any tips I have the tube already installed with the ps cooler hanging down maybe I have to pull it off again and install it first or do u guys relocate it?
Old Dec 24, 2011 | 05:38 PM
tech2262's Avatar
tech2262
Default test start
got it guys Thanks heres a video of my test start still have to put the fuel pump in but wanted to start it up http://youtu.be/ZyBfMu-rOzU
To A&A install question?
