Auto Swap Thread
#222
Hi guys
i just started my Auto swappe yesterday
all the manual stuff is out except the clutch pedal and the master cyl.
was working on the transmission harness i´m installing a Auto harness to the pcm , i have a jumper-harness from RPM.
i have unplugged all the manual harness plugs and i´m ready to plug the Auto plugs to the pcm plugs but i´m stuck on this one red wire that comes out of the manual harness loom and goes straight to the fuse box, but there isn´t any single red wire whith the auto harness.
what wire is that? has it something to do whith stability control or is it something else?
what should i do whith it?
thanks
Baezi
thanks
Baezi
#223
Hi guys
thanks
Baezi
thanks
Baezi
#224
i would also wante to know
1. are there different pin number between green and red connector to the PCM ( i have seen some ls1 whith red connectors )
i have 2004 pcm and it´s green and blue connectors
i already have a infos how to repin the jumperharness to the pcm connectors but they marke it B and R i assume it´s B for blue and R for Red or is it something else. but the thing is some of the pins already are taken so i would have to remove wires out first.
2, where do i find that two clutch switch wires (purple/yellow) in the PCM that goes to the pink tape wire in the jumperharness what´s the numer on it and in which connector is it. ?
3. what about the brake switch (i´m gona use my manual brake pedal)
4. did you guys wire up the shifter, i see there are 4 wire plug on it
thanks
Baezi
thanks
Baezi
#227
Not sure as i didnt do that
i ran mine staright back to the neutral safety switch
I didnt do anything with the brake switch, just left the maual pedal alone.
nope left it alone
nope left it alone
#228
1.) Not sure when your 2001 was built, but there were some minor changes mid year 2001 to some of the harness connections.
2.) RPM sells the bracket. Need to be welded up in the tunnel.
3.) Don't touch the wires inside. "C146" connector will plug into tranny harness connector and run back to tranny switch.
Baezi
#233
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I don't know for certain one way or the other, but, i heard/read it needs to be taken out.
I took mine out. No reason to leave it in.
#234
ok it was time to start it up
i´m missing something
allt pcm is pined up got instructions from RPM whith the jumper harness 16 new in and 4 out
i hooked the purple and yellow drom the CCP switch wire to the pink C146 connector
left the brake switch alone (using the manual brake pedal still)
Reflashed the tune after changin it from compared file from stock 2004 vette auto
the car now only cranks doesn´t start up
the fuel pump is working puming fuel but it doesn´t spark up
it only cranks in Park not N put if i press the CCP switch it start in all gears.
so guys what am i missing here, or am i having some other problem not related to this....
security light is blinking but No PCM codes
any one
Baezi
any one
Baezi
#238
any one
Baezi
any one
Baezi
#240
HI
where can i get new bushing for the shifter
the brown circle bushing that does on the nipple on the transmission
it´s broken, do i need complete net cable or is it sold somewhere
thanks
Baezi
thanks
Baezi
