stock MAF and MAP
Old Jan 10, 2012 | 10:15 AM
kj217's Avatar
kj217
Default stock MAF and MAP
is it possible to tune and run a 13psi procharged C5 with stock MAF and MAP?
Old Jan 10, 2012 | 12:30 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Sure it is. But you have to realize you are off the map for both airflow and manifold pressure. After the MAF maxes out you would need to start artificially raising the PE to keep adding fuel as RPM's and boost go up.
Having said that it's not a good idea. As I mentioned you cannot meter the airflow after ~5000 RPM's. It's better to get a 2 or 3 bar PAP and go with a multi-bar speed density tune.
Old Jan 10, 2012 | 01:14 PM
Nosferatu333's Avatar
Nosferatu333
what would you say is the limit on stock maf/map? Boost wise.
Old Jan 10, 2012 | 01:39 PM
5 Liter Eater
St. Jude Donor '11
The MAP will obviously max out as soon as you get into boost. I would SWAG the MAF pegging the airflow and frequency limits @ ~5000RPM. My old '99 with an A&A P1 kit maxed it out at ~5500 but I was only making 7# so you'll likely max out earlier.
Old Jan 10, 2012 | 02:08 PM
Robert 2000's Avatar
Robert 2000
My tune was recently redone went to speed density and I am not looking back. My car is running much better in SD in both drivability and up top. I don't have dyno numbers to know if the new tune makes more or less power.
Old Jan 10, 2012 | 03:17 PM
rclinton's Avatar
rclinton
Veteran: Marine Corps
Add a 2bar MAP sensor and go SD. A little more work to dial in the tune but worth the time and peace of mind.
Old Jan 10, 2012 | 05:03 PM
kj217's Avatar
kj217
can i go SD without access to a dyno?
anyone can help me through this remotely as i live in saudi arabia?
Old Jan 10, 2012 | 08:46 PM
Robert 2000
Yep my car wasn't dyno tuned
To stock MAF and MAP
