Question: AA Kit Oil Cap Modification
Old Jan 18, 2012 | 12:26 AM
a/c man's Avatar
a/c man
Originally Posted by TRIZ
Just be careful when filling the crankcase with oil; might get some oil in the catch can line if you have a hole in the filler neck; I did.
Lot of good info.
And thanks to Cammin 5 for the filler neck idea. Definitely would look a little cleaner.
cool idea tap the side of the filler neck!
Old Jan 19, 2012 | 07:52 PM
mig1980's Avatar
mig1980
would you still need to do this if you had an RX Performance oil catch can with a dual valve setup (for an SC'd car)? I purchased a catch can like this and will be installing it with my A&A setup soon. Just curious.
Old Jan 19, 2012 | 08:25 PM
a/c man's Avatar
a/c man
rx can should be ok unless you go over 10psi of boost
Old Jan 20, 2012 | 11:49 AM
mig1980's Avatar
mig1980
I have an oil cap and hose already setup with my used A&A kit. Can anyone tell me (possible diagram) on how the RX catch can would go connected to my kit with the oil cap and hose installed the way A&A does it? I tried contacting RX Performance and they have yet to send me documentation on the install.
