Question: AA Kit Oil Cap Modification
Old Jan 14, 2012 | 10:45 PM
RaW Z06's Avatar
RaW Z06
Default Question: AA Kit Oil Cap Modification
I have read the installation instructions for the C5 AA kit and noticed that the Oil cap is modified to accept a 90 degree fitting and hose that is connected to the air breather. Is this neccessary for the V3 Si kit that is self contained? Or, is this used only for kits that use oil from the pan for S/C lubrication???
Are there other options to relieve the pressure besides a hole in the Oil cap? The hose and fiting just look funky to me for some reason....
Does it bother anyone else or is this just the way it has to be done?
Old Jan 14, 2012 | 10:51 PM
ajrothm's Avatar
ajrothm
You can use an oil cap with the open breather attached to it but it will seap oil mist out everywhere on top of the engine and blower....
The A&A design vents the oil vapors to the air filter...(or in my case vents right to the ground under the car)..
Old Jan 14, 2012 | 11:19 PM
RaW Z06's Avatar
RaW Z06
I took a picture of this Procharger kit which was at a local car show. The owner claimed that AA did the install and tune around 6 years ago. It does not appear the Oil cap is modified. I didn't see an open breather either. I wish I knew how to get ahold of the guy who owns the car. I like the clean look. I just wonder how pressure is relieved with his system.
Old Jan 15, 2012 | 01:28 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default Crankcase Evacuation
There have been many changes over the years - usually to make things better - in the kits most reputable vendors supply.
There is a whole thread that may be of interest -
http://forums.corvetteforum.com/c5-f...on.html:*****:
Old Jan 15, 2012 | 01:38 AM
bullitt4110's Avatar
bullitt4110
It is for crank case ventilation purposes, you should do the A&A way at the very least.
Old Jan 15, 2012 | 01:39 AM
ajrothm's Avatar
ajrothm
Probably by blowing the dipstick out everytime he runs through the gears...lol..
You HAVE to have something to vent the crank case besides the PCV... Especially if running more the 7-8psi of boost..
I had two different breather style oil fil caps, both left an oil film all over the top of the engine covers and blower/brackets....nasty. The A&A vent tube system is the way to go. I used a chrome plated 90* fitting for the oil cap and concealed the hose as much as possible. It looks ok.
Old Jan 15, 2012 | 02:03 AM
Milan's Avatar
Milan
Get the ECS oil cap...it has a filter to keep it from blowing oil all over your SC...works pretty well
Old Jan 15, 2012 | 08:20 AM
helga203's Avatar
helga203
Or he never gets into boost.
Old Jan 15, 2012 | 09:08 AM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
I drilled and tapped the filler cap neck instead of the filler cap. Looks more clean and easier to remove and replace the filler cap.
Old Jan 15, 2012 | 12:54 PM
a/c man's Avatar
a/c man
you can run vent hose from the valley and valve cover vents to the breather can even run 2
Old Jan 15, 2012 | 03:25 PM
RaW Z06's Avatar
RaW Z06
I'm thinking this may be a good option
Old Jan 15, 2012 | 03:36 PM
CamminC5's Avatar
CamminC5
I'm going to re-plumb the system. A certain thread has got my gears turing on the topic.
However, this is probably adequate for low cfm/boost setups. Correct me if I'm wrong.
Old Jan 15, 2012 | 04:34 PM
RaW Z06's Avatar
RaW Z06
What kind of boost are you running with your current set up. Have you experienced and problems taped into the filler neck??
Old Jan 15, 2012 | 05:45 PM
CamminC5's Avatar
CamminC5
10-11 and I'm sure this way is fine for now, but I plan on going with a bigger SC soon. No, but I wrapped the threads with teflon because there was some residual oil at first, but not now.
Old Jan 15, 2012 | 11:44 PM
4SFED Z's Avatar
4SFED Z
Install it the way it was intended to be installed. There is a reason andy designed it this way.....
Old Jan 16, 2012 | 12:11 AM
TRIZ's Avatar
TRIZ
Yea,
There is a reason Andy did it this way. He tapped the oil cap because it it is the highest point in the crankcase volume and results in the least oil getting pulled back into the intake manifold/catch can - however you routed it.
Andy used to pull off the valve cover - this resulted in alot of oil in the intake/catch can.
Old Jan 16, 2012 | 07:43 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
Originally Posted by TRIZ
Yea,
This is correct.
__________________
Thanks, Josh Dodson
Sales Manager at A&A Corvette
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
Facebook.com/AACorvette
To Question: AA Kit Oil Cap Modification
Old Jan 16, 2012 | 07:57 PM
CamminC5's Avatar
CamminC5
Still installing it at the highest point of the system. Just makes it easier to remove install the filler cap. Not to mention it looks better.....BTW I don't have any sign of oil residue in the intake or SC.
Old Jan 16, 2012 | 10:47 PM
RaW Z06's Avatar
RaW Z06
Yea,
I can appreciate the idea behind the Cap being the absolute highest point
However, common sense tells me the side of the the filler neck would work equally as well
Old Jan 18, 2012 | 12:21 AM
TRIZ's Avatar
TRIZ
Just be careful when filling the crankcase with oil; might get some oil in the catch can line if you have a hole in the filler neck; I did.
Lot of good info.
And thanks to Cammin 5 for the filler neck idea. Definitely would look a little cleaner.
