RX Catch Can Install?
Old Mar 30, 2012 | 04:23 PM
Milan's Avatar
Milan
So I spun the one all the way to the left (or right) around. Then the one on the other side I pulled out as much as I could and kinda set it at an angle. This allowed me to spin the middle one around. You have to muscle it through and it's a huge pain in the ***. It took me a lot of cussing and I'm half way tempted to post a negative review on these things on here and LS1tech since customer service has been non existent.
Old Mar 30, 2012 | 07:43 PM
Milan's Avatar
Milan
So here is where I am at so far on the install. I got everything mounted up. I couldn't really find a good way to run from the passenger side valve cover to the catch can so I just said screw it and went to the valley cover instead. I'm gonna see how this works for starters and in the meantime i will look for another solution.
Old Apr 8, 2012 | 12:15 PM
algZO6's Avatar
algZO6
so how is it working out for you?
Old Apr 8, 2012 | 03:18 PM
Milan's Avatar
Milan
Hard to say really...it seems like it threw off my cruising and idle trims a bit....haven't logged WOT yet.
Not really sure if this mod is worth the money. RX has the worst (non existent) customer service too.
Old Apr 8, 2012 | 09:14 PM
algZO6's Avatar
algZO6
i guess it looks like i will be throwing my elite back on my car.
Old Apr 9, 2012 | 01:48 AM
Milan's Avatar
Milan
Definitely would not get rid of an existing catch can in favor of this one.
Old Apr 9, 2012 | 12:41 PM
turbocrazy's Avatar
turbocrazy
I'm not going to lie, this is really disappointing. I have one of these catch cans as well that is going to be installed when my car goes to ECS and I am starting to question this decision along with the purchase. This really shows me just how important customer service is. If I knew how, I would email this entire thread to RX Performance and see if that gets their attention.
Old Apr 9, 2012 | 01:12 PM
robert miller's Avatar
robert miller
The Bat Car is his avatar name in here to me he is a super nice guy. He will call you back and help dont care how long it takes on the phone. His cell is 727-422-0076 give him a call will for sure help you and also call you back.... Robert
Old Apr 9, 2012 | 01:24 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Try this link...Post #3
http://forums.corvetteforum.com/c5-f...n-install.html
Old Apr 9, 2012 | 01:35 PM
turbocrazy's Avatar
turbocrazy
Originally Posted by 95wht6spd
I just sent The Bat Car an IM, so maybe he will reply to the thread.
Why?
I don't see his reply.
Old Apr 9, 2012 | 01:37 PM
Milan's Avatar
Milan
That link doesn't work for me.
Not to nitpick, but another thing I don't like about the can is the A&A bracket. I mounted min up just fine but for those of you installing it in the future you might want to learn from my mistake. If you mount the can flush with the bracket (this will make sense when you do it) it will be too high. I tried mounting it flush first and although it was lower than my breather filter, I didn't take into consideration the angles of my hood. Anyway to make a long story short, my hood closed just fine but what I didn't realize is that the valve furthest to the front was actually hitting my hood in one spot and now I have a nice spider crack in my paint from my stupidity.
So be warned, mount the can as low as you can otherwise you might have the same problem as me. There is not a lot of room to work with in the bracket if you use both mounting holes on the can, maybe 3/4"
Old Apr 9, 2012 | 01:59 PM
robert miller
I do agree with you on this but also really not much room in this spot. I am pulling my battery and putting it in the back of the car as soon as I do that I am putting my can over in that spot. Robert
Old Apr 26, 2012 | 08:47 AM
  #33
EBM_Z06's Avatar
EBM_Z06
Where did you connect the 3rd hose... the one that is not connected in the picture. Did you connect it to the A&A air filter of the supercharger head unit ? Or did you drill a hole into the plastic air intake in order to setup a hose barb (just like here) ?
How is the can working for you ? Did it mess with the WOT trims ?
Old Apr 26, 2012 | 02:30 PM
  #34
Milan's Avatar
Milan
I connected it to the filter, I'm in the middle of doing the 4" intake mod, so when I do that I will put it in the tube.
Haven't had time to go log my car since the catch can install.
Old Apr 26, 2012 | 05:11 PM
  #35
robert miller
You are correct here by what BAT CAR showed me and how he said to do it...The pic, that the guy posted up on the 1st page here is correct but with the A/A front mount you drill a hole into the intake tub like Milan has said he was going to do above. BAT CAR said he gets better air into it the shorter your tube is from the C/can.... Robert
Old Apr 26, 2012 | 08:33 PM
  #36
95wht6spd's Avatar
95wht6spd
Ok so for LS6 w A&A one goes to intake dongle, one goes to valley, and other to nipple behind TB?
Old Apr 26, 2012 | 08:56 PM
  #37
Milan's Avatar
Milan
Yes
To RX Catch Can Install?
Old Apr 26, 2012 | 10:01 PM
  #38
Lt. Dan M.'s Avatar
Lt. Dan M.
is a catch can necessary if you have a vented valve cover cap?
Old Apr 26, 2012 | 10:05 PM
  #39
robert miller
Yes you will still get the oil into the intake..
Old May 25, 2012 | 01:51 PM
  #40
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
What nipple behind the TB? Did you just cap off the port on the driver side V/C? Or connect the drivers and passenger side V/C together?
** Nevermind I just spoke with BatCar on the phone and all is well**
