RX Catch Can Install?
Old Mar 28, 2012 | 02:10 AM
BlueTeamZ06's Avatar
BlueTeamZ06
Default RX Catch Can Install?
Howdy! I just gor the RX Catch Can for FI (i.e. the one with three openings and the check valve) as well as the vented oil cap for the passenger side valve cover.
Question- I am fine with the connections to the intake and the nipple just behind the throttle body, I'm just not seeing the one on the Driver's side valve cover. Anybody have pic of their setup?
Also- I have an A&A bracket, if I use the longer bolt as recommended, what are the torque specs for the bolt?
Thanks!
Old Mar 28, 2012 | 02:56 AM
Milan's Avatar
Milan
I'd like to know too. I've tried a couple times to get clarification from them but haven't received a response. Annoying to say the least.
Only thing I've concluded is that is something that LS1's have that LS6's do not have.
Old Mar 28, 2012 | 03:36 AM
BlueTeamZ06
I have also sent a PM, no response from BatGuy. It is a bit annoying.
I specified when I bought the catch can that it was for a Z06, hence LS6. I would have liked to have been told that this was not a complete solution or that I would need to tap my valve covers for another breather if that is what is needed.
Can somebody else speak up on this who has installed this solution on a Z06?
Old Mar 28, 2012 | 03:45 AM
BlueTeamZ06
OK so check this out:
http://www.ls1howto.com/index.php?article=18
Seems the LS6 pulls from the valley cover. So we need to be connecting to that. Now where is that hose routed in the stock setup?
Old Mar 28, 2012 | 04:28 AM
Milan's Avatar
Milan
That's what I thought too. When I emailed them I asked about that exactly. Also I need to know which valve on the catch can has a check valve.
Old Mar 28, 2012 | 08:45 AM
barrynk's Avatar
barrynk
Here's my installation (2001 C5 vert) :
Image modified from LS1.com
I was able to reuse the elbow connection at the back of the driver's side valve cover, and a couple of hose clamps. Everything else was replaced with parts from the RX kit.
Old Mar 28, 2012 | 09:20 AM
BlueTeamZ06
That pic is included in the RX instructions and is for the LS1. It seems that the LS6 is vented via the valley, I think I located the hose coming from the correct vent and will run it to the catch can instead of the one coming from the valve cover which does not exist on the LS6.
But it would have been nice to have been told about that by the guy who sold me the catch can. He still hasn't answered my PM...
Old Mar 28, 2012 | 12:07 PM
95wht6spd's Avatar
95wht6spd
I need to know too, just got my RX can in and have an LS6.
Old Mar 28, 2012 | 12:28 PM
bullitt4110's Avatar
bullitt4110
The LS6 does vent from the valley cover.
Old Mar 28, 2012 | 01:43 PM
robert miller's Avatar
robert miller
I have the RX 2 can set up on the car..Robert
Old Mar 28, 2012 | 02:02 PM
Milan's Avatar
Milan
So instead of running the line from the back valve cover we run it to the valley cover instead?
Old Mar 28, 2012 | 08:30 PM
95wht6spd's Avatar
95wht6spd
Does this require modification? Anyone have a pic or diagram?
Old Mar 28, 2012 | 08:34 PM
Milan's Avatar
Milan
Found this...doesn't really help too much, im still confused
http://www.ls1tech.com/forums/11059703-post70.html
Old Mar 28, 2012 | 09:00 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I have no experience with the RX can, but can you not just "T" into the line coming from the drivers VC with a line from the valley cover?
Old Mar 28, 2012 | 10:13 PM
mig1980's Avatar
mig1980
Off topic but what type, size hoses would I need to connect this can?
Old Mar 28, 2012 | 10:16 PM
Milan's Avatar
Milan
Okay guys I think I got this all figured out...will post results tomorrow.
95wht6spd's Avatar
95wht6spd
I just sent The Bat Car an IM, so maybe he will reply to the thread.
To RX Catch Can Install?
Old Mar 29, 2012 | 04:29 PM
SuperSteve04Z's Avatar
SuperSteve04Z
I am waiting on purchasing this item until I get good info on how to install it on an LS6. Car is down so I want to add a catch can asap.
Old Mar 29, 2012 | 07:20 PM
Milan's Avatar
Milan
Well I'm half way through installing mine, The valves in mine were facing the wrong way, so I had to try to spin them around so that they would face the right way. This was a HUGE f'n pain in the ***.
I've almost got everything mounted up...I just hope this POS actually works. Great idea, poor execution
Old Mar 30, 2012 | 04:15 PM
95wht6spd's Avatar
95wht6spd
I think my valves are on the wrong way too, they are facing to the right WTF!?
How did you turn them?
