Help!!!!
Old Apr 15, 2012 | 09:17 PM
jmuck's Avatar
jmuck
Default Help!!!!
Alright guys. Here's my problem.
First off, I have searched for the better parts of 6 hours and followed every little tip, trick schematic etc and still can't get this damn car to hit the starter.
Just got the engine back in and buttoned up ready to start priming it for the first fire up.
All grounds are as they should be, have tested bcm yadda yadda. Starter wires are all hooked up. I can turn the key and nothing. You can hear the relay in the passenger footwell click, but it does NOTHING.
Here's what its doing. Go get in your car (man. trans) Put it in neutral and DO NOT press in the clutch. You turn the key to the run position and you get nothing. Repeat the same sequence and push the clutch in like you are supposed to, you get the same result.
This car had zero starting issues before I pulled the engine. Now its dead in the water.
Old Apr 15, 2012 | 09:52 PM
robert miller's Avatar
robert miller
Is the battery good...also your in line fuse its not blow some how is it..
Old Apr 15, 2012 | 10:22 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Understand the grounds are hooked up, but are the surfaces clean? Did you paint the block? It really sounds like a ground issue.
Check for continuity the fuses. Sometimes they don't look blown but they are.
Old Apr 15, 2012 | 10:24 PM
corvette8189's Avatar
corvette8189
starting wires hooked up right?
grounds? behind the head on driver side
battery
just throwing stuff out there
Old Apr 15, 2012 | 10:26 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yeah this one will really fk your day up....ask how I know
Old Apr 15, 2012 | 10:33 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
phone call coming
Old Apr 15, 2012 | 10:39 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Bbz ftw. Sidenote. Text me update on your car.
Old Apr 15, 2012 | 10:43 PM
BLOWNBLUEZ06
Old Apr 16, 2012 | 10:26 AM
jmuck's Avatar
jmuck
Brett, thanks for the phone call.
Driver's head ground. Check
Ground strap from frame to block. Check
Battery. Check
Grounds on pass side of engine. Check (move to head actually b/c I was worried about the paint on the block screwing things up)
Wires on starter hooked up. Check
All fuses in starting system. Check
I am going to check the wire on top of the starter with a volt meter to verify that clutch switch is working correctly.
Also, I may have found the issue. Last night I was reinstalling the wires back onto the starter and checking the nuts on the post when the negative side post broke while trying to tighten it up. I did notice that post had some play in it when I was putting the starter in last week. I'm hoping and thinking that was/is the problem. Picking up a new starter today, I'll pull the header loose and hope this fixes the issue. Thanks for the reply guys and I'll post back after the new starter is in. Wish me luck.
Old Apr 16, 2012 | 10:45 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
That lug is a common problem. It's just held in by the plastic of the solenoid and after being heat cycled it gets brittle. It's not a negative though as the starer just grounds to the block. Could be the problem.
Gremlins...
Old Apr 16, 2012 | 10:52 AM
jmuck's Avatar
jmuck
Gremlins...
After more reading, that's what I've seen also. Like I mentioned, it was in fact loose when I was installing it before hand, so hopefully it fixes it. All wiring is as it should be.
Those damn gremlins man....
Old Apr 16, 2012 | 11:21 AM
user_name's Avatar
user_name
I ****ing hate messing around with those starter wires. They gave me hell on my build as well. Next time that is all apart I am making new wires with slack and routing them differently.
Old Apr 16, 2012 | 11:35 AM
jmuck's Avatar
jmuck
Me too. Especially with 2" LT's. I am def redoing all of mine once I have the time.
Old Apr 16, 2012 | 12:37 PM
corvette8189
you'll be saying that alot, i hate working anywhere near them headers.
Old Apr 17, 2012 | 09:10 AM
jmuck's Avatar
jmuck
Well she turned over last night!!
Installed a new starter and while I was in there, I extended the wiring for it and man that made life a lot easier to get it hooked up. While the new starter did not fix the issue, I did some more trouble shooting. I went back over the starter fuse and ignition fuses in the pass foot well. The starter fuse(60 amp maxi) did not look blown, after close inspection I noticed that it had a "bow" in it. I replaced it, hit the key and magic happened!!! Thanks CamminC5 for mentioning that!!!
So the rush is on tonight to get the new fuel tank in, replace the spindle and get the pass header back on and get it loaded on the trailer.
Old Apr 17, 2012 | 01:36 PM
Milan's Avatar
Milan
Sweet man!! Happy for the positive turn of events for you
To Help!!!!
