dyno preference
Old Apr 28, 2012 | 05:36 PM
4SFED Z's Avatar
4SFED Z
Default dyno preference
What is your dyno preference? Mustang, dynojet,.......
Also, what's your take on them? Safe? Any recommendations in west hoiston area?
Old Apr 28, 2012 | 05:52 PM
optimum01's Avatar
optimum01
Hoiston?
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
I prefer a load bearing (Mustang) type. I'm sure all of the dyno vendors have improved their offerings over the years, but at the end of the day I'd want whatever my tuner felt would be the most appropriate tuning tool for my needs.
This is really the only purpose of the dyno - for tuning and benchmarking. Numbers can vary greatly from one dyno to another.
Old Apr 28, 2012 | 05:54 PM
Robert 2000's Avatar
Robert 2000
I don't really have a preference and Darren doesn't have one. However, my car was dynoed at Futral motorsports when I wanted to get numbers out of it. I have a few buddies that get there cars worked on there and they have a dynojet. My car may not see a dyno again unless if it is ever dyno tuned by Darren in the future.
Old Apr 28, 2012 | 07:03 PM
4SFED Z's Avatar
4SFED Z
Mustangs read lower right? Why?
Old Apr 28, 2012 | 07:22 PM
Robert 2000
Dyno Dynamics read lower also... I am not sure why tho
Old Apr 28, 2012 | 11:03 PM
joshtownsend's Avatar
joshtownsend
Dynojet is a free roller and mustang is load bearing
because of drag ... or the lack there of... The more "load" or restriction the wheels have on the roller, the less power it will show.. this is why other shops that i have seen will pull lighter tires and take or rear brakes and tons of other things to get the highest number possible because we all know.. numbers = sales.
If you really want it tuned right... road tune it. its by far the best way to tune a car. Its the only way i tune my car.
Old Apr 29, 2012 | 02:44 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
dynapack!
Old Apr 29, 2012 | 02:46 AM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
That's exactly the way Chad's car is tuned, just want to put it on a Dynojet to see where she's at.
Old Apr 29, 2012 | 05:19 AM
4SFED Z's Avatar
4SFED Z
Just trying to see what differences are as there are several to chose from.
Arun did an awesome job tuning the car. He is da man.
Old Apr 29, 2012 | 08:45 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Every car should be street tuned to a point of safety of course. I'm not a fan of going 140+mph in a customers car and risk crashing it.
We do a full street tune then hit our full load mustang dyno to do all the WOT tuning. I love this dyno over my old Dynojet because it put's a good load on the car which helps alot with timing/fuel adjustments.
On our old dynojet it was common to put in too much timing and see no knock on the dyno, then going down the highway at full load the car would knock/ping. A non-load dyno can also not show fuelling problems.
Old Apr 29, 2012 | 08:57 PM
4SFED Z's Avatar
4SFED Z
Car was street tuned by Arun. Not tuning it. Car was ran up to 6500 at WOT. Its perfect.
Found an eddy dynometer nearby....
Old Apr 29, 2012 | 11:03 PM
joshtownsend
I understand from shops prospective... Still don't believe in it.. will it be close.. of coarse.. It mainly would depend on where you live as well.. 140 aint fast here.. I would much rather tune on the street at 140 then do it on any dyno then go race someone and hit 140 for the first time on the street with a 100% tested tune. I am a firm believer in train like you race.. weather it be running, baseball or cars.. its all the same from sport to sport. Knowing where yuor going to be at exactly is priceless info.
Old Apr 29, 2012 | 11:09 PM
Robert 2000
My question in all this is if the car is tuned with 3rd and 4th gear pulls so up to roughly 140-150 which is do able for sure. Will it act differently in a 5th gear pull and I imagine you can't tune a car on the streets at those speeds. But if I were to run say the mile and use 5th gear how can you be sure the tune will hold up through the long 5th gear pull?
Old Apr 30, 2012 | 12:04 AM
joshtownsend
4th is 1 to 1
5th pulls just a hard when you make big power..
gear make no difference what so ever..in theory. The reason you use 4th is to get a better resolution of the data being taken thru the run.. and prevent wheel from losing traction which will mess up the data. While in WOT, you command things to happen.. that motor don't know, nor care what gears its in.. it just whats to be happy with the proper A/F ratio for your setup. If something goes wrong on a long 5th gear pull , its not because of the tune but because the parts cant handle it.
As for street tuning.. Think about going across lake Pontchartrain when nobody it there.. That is exacalty what its like where i tune. So 140 or even 190 is not an issue with cars or road space. My car gets there quickly, then i shut it down.. really about 1.5 miles for everything..
Old Apr 30, 2012 | 12:42 AM
Robert 2000
4th is 1 to 1
Okay good point I get what your saying and lake Pontchartrain without anyone there now that would be fun. I was thinking that since the load on the engine should be higher that would make a difference in a 5th gear pull but I understand what you are saying about parts being the real issue.
Old Apr 30, 2012 | 09:49 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by MVP'S ZO6
dynapack!
I have tuned on all the major dyno brands and I have found the Dynopack to offer the exact same readings/load etc as on track or street. Problem is you wont find many shops willing to pay three times the cost of a Mustang, or twice as much as a Dynojet for these results.
To dyno preference
